Question about Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS
No constant hot water...
Okay I just installed a new water heater last month from sears, its connected to a timer that u can manually switch to on/off setting. the new water heater has 2 heating elements, one on the top & one on the bottom to ensure you'll get hot water everytime.. okay heres the problem, the timer is set from 5am-11pm, inbetween those times there should have hot water constantly until the cutoff time.. okay when I used the shower in the morning around 8am there is hot to warm water for a short peroid of time then its starts to come cold, this also happens around lunch time & sometimes in the afternoon.. what could be the problem to this? also can this be the cause of having a high electric bill??
  • 6 more comments
  • gtstoenvy Jan 23, 2009
    ^^ okay Sears technicians checked out the water heater yesterday, said that the upper/lower heating elements are ok but the thermostats had to be change.. he change them both... upper is set to "A" & the bottom is set to "B".. the problem still stays the same after 30 min of waiting for the hot water, it sames like its not heating up like it suppose to. what else should I do, get another water heater installed since its still under warranty or try to figuire out whats wrong with this one?
  • gtstoenvy Jan 24, 2009
    ^The technician checked for proper voltage & said it was reading correctly, as far as leaving it on for 24hrs, do i take the trippers off the timer wheel off? the timer that is connected to the WH is a Intermatic model # T104R which has that yellow wheel to set your on/off times..
    ^ on another note, should both thermostats upper/lower be @ the same degrees or should the lower one be higher than the upper one...
    okay imma take the trippers off 1st thing in the morning tomarrow, as far for setting the upper and lower thermostat, sears technician told me the lower thermostat should be a lil higher than the upper thermostat?? I also read some articles on the web saying it should be kept the same, & u said the upper should be a lil higher than the lower..i'm kinda confused??? which one is the right setting..the tech set the bottom thermostat to 130 degrees & the upper to 120 degrees factory setting!! lmk thanks
    ^imma try adjust the thermostats, i'll make the top @140 & the bottom @ 125-130 & i'll see what happens..
  • gtstoenvy Jan 26, 2009
    I took off the on/off trippers on the timer to run it for 24hrs and adjusted the thermostat to 140 degrees top & 125 degrees bottom, still dont got constant hot water, it goes from warm then to cold... dunno but I think theres a leak in the main piping somewhere to cause this just a thought beacuse my brother in law had a similar problem where they change the WH 3x & come to find out there was a leak in the pipe...
  • gtstoenvy Jan 27, 2009
    ^^^ I already turned off the cold water shut off valve on the top so no water is entering the tank, the tank is already full but we won't be able to use the hot water becuase the cold water valve is shut close.. what do u mean by crack a hot water valve somewhere in the sink??
    ^ n/m its a leak in the pipe, after shutting down the cold water valve going to the WH for a few hours, i did a different test if it will work, I open the hot water faucet from the sink then open the cold water valve from the WH just so that hot water will come out & next thing u know hot water did come out this time!! damn wasn't the WH all alone it was a leaking pipe... thanks for your help though..
    Scholar:
  • 39 Answers
Only two things come to mind. Either the clock is not set to the correct time (which I'm sure it is) or one of the elements most likely the bottom one is not heating for some reason. I would start by leaving the heater on 24 hrs by removing the trippers and switching it on. See if the problem goes away. If it does then focus on the timer settings, give it more warm up time etc. Make sure the clock is set to the right time and keeps time. If the problem persists on a 24 hrs running schedule then focus on the elements. --Turn the power off at the breaker-- and remove the access cover for each of the elements and or thermostats. Check the thermostat settings on each element for reasonableness. Sometimes the thermostat is covered by insulation material. If you need further assistance please write back with more detail. I can walk you through an element checkout if you have an AC volt / ohmmeter but since its new it should been under warranty.
Posted on Jan 19, 2009
  • 3 more comments
  • Ty Parcher
    Ty Parcher Jan 23, 2009
    If its set to be on 24 hrs a day and still is cold make sure you have voltage to the heater all the time. I should think the Sears man would have checked for proper voltage. Caution. Its probably 240 volts which is deadly if you don't know how to measure and verify voltages safely don't try to do this. Get Sears back. If the hot water heater is on a timer set it to allow 3 hrs to heat up the water all the way from the top to the bottom before expected use. Since you are having trouble I recommend you leave it on 24 hrs a day until the problem is resolved. Once the heater reaches temperature it will shut itself off anyway. All the timer can save you is the very small amount of energy otherwise lost through the heater's insulation and connecting pipes to maintain the water temperature during periods of none use.
  • Ty Parcher
    Ty Parcher Jan 24, 2009
    Just unscrew and take the trippers off. Leave the timer disk with the pointer pointing to the current time.
    Push the on - off lever below the disk to the right "on" position. Your done.
    The temperature at the top of the heater will always be higher that at the bottom because hot water rises in the tank. The top element should be set to the temperature you want for use. The higher the temperature the less hot water you need to draw at any time but if you make the water too hot you or someone in your home can get scaled by accident and the efficiency of the heater will be worse. I like to set the temperature to an amount that is as high as I can tolerate without getting burned. Somewhere around 140 degrees F Should be right. The lower element I would set to be about 125.
    Write back if you need more help.
  • Ty Parcher
    The cold water that enters the hot water heater goes down through a tube inside to the bottom of the tank. Therefore the bottom will get cold first. When the bottom element heats the water it rises in the tank to the top by a process called convection. Therefore the top will always be hotter than the bottom. Therefore I set the top element a little higher. Otherwise it tends not to run very much and most of the heating load is taken up by the bottom element. I set for a more balanced heating load to get a faster recovery. Hot water is drawn off the top so the top element heats a small quantity in the top of the tank and cuts off. That's why I set it higher, so I get more work out of the heater over time. If I wanted a more even temperature at the outlet I might set the bottom higher than the top but the total recovery time would be a bit slower. Its not real critical. If you want more capacity out of your heater 120 degrees is a little low. 140 degrees mixed with cold water at the tap will have the effect of extending the tank capacity as the hot water draw (gallons per min) will be less for the same working temperature at the tap or shower head.
  • Ty Parcher
    Ty Parcher Jan 26, 2009
    Yes a leak would do it if the leak was bad enough. The hot water heater could never catch up if there is too much constant flow. If you think its a leak then you can try turning off the cold water supply line to the tank and then crack a hot water valve in a sink somewhere so that as water heats up in the tank it can expand. That way the water in the tank will stay there and get heated. Let a few hours pass and then turn everything back on again. If you have plenty of hot water then there is a leak. Of course, if the cold water shut off valve does not close tightly (because it doesn't get used much and corrodes) this will method not work.... but its a thought.
  • Ty Parcher
    Ty Parcher Jan 27, 2009
    "crack a hot water valve in a sink" figure of speech "crack" open a valve means open the value just slightly. Glad to be of service.
No Hot Water
Hard water contains a lot of minerals and depending on how hard the water is also depends on how often you must replace the filters. A much better alternative is to have a water softener installed before your hot water heater and any other sorce of domestic water supplying your home. I have one and it works great. Just be advised that you will need to replace the salt crystals every couple of months depending on the time intervals you set the timer to. If you find that the water still remains soft after two months and your filters are not to badly clogged then you may try adding salt every three or four months and see if that solves your problem. You also have to remember that your also using the water for drinking cooking and bathing so softening your water supply is very important especially if you or anyone in your household ever had any kidney stones or kidney problems.
Good luck,
Marty
May 08, 2014 | Navien CH-240-ASME-LP, Combi Condensing...
No hot water - timer not moving
If you have a meter carefully check power to timer. If there and there is no power out of timer replace it.
Nov 30, 2017 | Intermatic WH40 - Water Heater Time Switch...
How do i install a pressure tank to my water heater?
Do you mean expansion tank? To relieve pressure?
Expansion tank goes on cold water line before cold enters tank.
See image:
http://waterheatertimer.org/images/water-heater-expansion-tank.jpg
Expansion tanks are installed when TP valve is constantly drizzling hot water due to very hot temperature settings. Or when water pressure is high, etc
It's also smart to install expansion tank so plumbing lasts longer, and older tank is less likely to rupture and cause damage. Inspect tank for leaks each 6 months.
Some regions require expansion tank by local code.
Water heater can be damaged when pressure exceeds 80psi. : Test pressure using pressure gauge at water heater drain valve.
Other resources:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
http://waterheatertimer.org/images/BTG-100-Pressure-gauge.jpg
Sep 27, 2011 | General Electric Water Heaters
I have the AutoCirc fixed thermostat model, and I installed it last fall as part of my bathroom remodel. It worked great for a couple months, but now it does not seem to be functioning at all. I have...
If pump does not turn on when set to ON, then it sounds like pump has gone bad or timer has gone bad.
http://waterheatertimer.org/Water-heater-recirculation-system.html
If pump runs but hot water does not show up, then you might have crossover problem:
http://waterheatertimer.org/Crossover.html
Recirculation systems cannot be exposed to hard water, or pump parts clog.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 27, 2011 | Laing Thermotech Autocirc Undersink...
Cannot light pilot on 4 year old heater rheem tells me part not available in supply house is this right part i need isvile that is broken below pilot light
I can't tell if you have tankless or tank heater.
Rheem has gone big into tankless the last few years and maybe first models don't have parts any more.
Even so, Rheen probably sells the whole burner assembly.
Most plumbers prefer to replace whole assembly so they're not doing a call-back next month.
Check with Rheem for whole assembly.
Another option is to roll the Rheem heater out of the way and install generic brand from Ace, Home Depot, Sears, or Lowes. Read manual cover to cover to prevent failure. Keep dust, lint and chemicals out of same room. Loosen anode rod before installing. Connect ground wire jumper to hot and cold pipes.
Fix the Rheem when parts become available, or use it as tempering tank to passively preheat incoming cold water, or set tank in wood box with glass cover and make passive solar tank.
Feb 14, 2011 | Rheem Water Heaters
I have an intermatic WH40 timer that works great when it is "On". However, once the unit encounters the "Off tripper", it turns the hot water power off, but the timer dial no longer...
If this is new installation, you have Load wires and Breaker wires reversed.
http://waterheatertimer.org/How-to-wire-WH40.html
http://waterheatertimer.org/images/WH40-water-heater-circuit-5.jpg
Hot wires from breaker connect to terminals 1 and 3 ... notice also there are small white wires connected to terminals 1 and 3.
Small white wires go to 240Volt clock motor located on back of mechanism, so these terminals have to be Hot all the time so clock motor is ON all the time >> thus hot wires from breaker connect to same terminals that have small white wires.
Load wires to water heater connect to terminals 2 and 4
Reverse your wires and things should work fine.
Dec 05, 2010 | Intermatic WH40 - Water Heater Time Switch...
New Intermatic WH40 electric water heater timer for solar
make sure your line wire is on the correct connection seems to be connected to the off going contact. then the clockmotor runs only if timer is switched on. to be sur there is a diagram on electricsuppliesonline.com, search/shop by brand, intermatic. good luck
Dec 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
Wiring a wh40 intermatic timer to a sears hot water heater
Shut off breaker to you water heater. STILL TEST FOR VOLTAGE BEFORE YOU TOUCH ANY WIRING. The 3 wire that go to you water heater disconnect them. You are going to install them to your WH 40 timer.
The wires that you disconnected will now go to terminals: Black to Terminal 1 & White To Terminal 3, The Ground copper wire will go to the ground terminal should be a green screw.
You will have to buy some 10/2 wiring to go from your timer to your water heater. You can buy it by the foot at Lowes. Figure how much you will need.
With the new 10/2 wire install the Black to terminal 2 & White To Terminal 4, the ground wire will go to the ground screw with the other ground wire.
Wiring that went to terminals 2 & 4 will be installed to you water heater, the same way when you disconnected them. Set your timer clock and your done. Turn breaker back on!
Dec 28, 2008 | Intermatic WH40 - Water Heater Time Switch...
Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS Logo
319 people viewed this question
Top Intermatic Water Heaters Experts
Steve
Gary Nitowski
ray gallant
Are you an Intermatic Water Heater Expert? Answer questions, earn points and help others
