White horizontal line issue
SOURCE: Epson Photo R265 Lines every 2.5 cm
clogged nozzle, run the clean head then test page in this order at least 5 times in a row, you should see an improvement on each test page, sometimes you need to keep doing this clean/print until the nozzle becomes unclogged, if you don't see a difference in the 5-10 clean/test page then you need a new head
hope this helps
Thanks for your rating
SOURCE: EPSON LQ 1050+ printer; OS Windows XP, How to Print long pages of 24" length
My LQ1050 is cutting off text at the bottom what could be the problem please help?
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
SOURCE: PROBLEME OF MY EPSON LQ 2090
whene i turn up my epson, i have a bip soone and all the leds are lighing
