Question about Samsung HL-S5087W DLP TV
Samsung HL-S5087W wont hold the settings
Set started not holding its settings after about 5 minutes.
    New Friend:
  • 111 Answers
I think problem is with your tv's system control section and please do not do anything if you are not familiar with electronics.
if yes please find the sys control section and find the serial eeprom
thn come again.
nuwan.
Posted on Jan 19, 2009
HL-S5087W IS WORKING RIGHT NOW, BEAUTIFUL PICTURE BUT AFTER 20 MINUTES THE PICTURE GET OUT. THE LAMP IS NEW.
I went through the same exact thing. I had to replace the DMD board. No problem after that.
Feb 26, 2015 | Samsung HL-S5087W DLP TV
Low volume on Samsung HL-S5087W
Check the caps on your power supply, could have a problem with your audio voltage. If the caps are good, I would say that your main board is defective.
Mar 21, 2013 | Samsung HL-S5087W DLP TV
Changing the bulb in a SAM HLS5087W
The lamp will be located either on the left side or on the back of the set----look for a door secured with one or more screws.
With the set unplugged, open the door and back the two screws that hold the lamp (it is in a cartridge with a handle) and grasp the handle and slide the lamp out.
Slide new lamp on (lots of them on the internet but buy a Samsung one and not a Generic "bulb".
Replace the door making sure you put the screws back that hold the lamp/cartridge in. Plug the set in and see what you have.
It is that easy--meant to be customer replaceable.
If this told you something you did not know rate this solution as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Samsung HL-S5087W DLP TV
Samsung HLS5687W XAA will not stay on
You might have the problem with your standby processor on it, that needs samsung technicians.
May 03, 2017 | Samsung HL-S5087W DLP TV
I HAVE A 50'dlp SAMSUNG TV-HL-S5087W THAT TURNS OFF
probably a bad (intermittent) control board.
Nov 14, 2009 | Samsung HL-S5087W DLP TV
Screen blacks out on samsung DLP
It may be a loose conetion inside the set. Open and carfully check the conections.
Aug 20, 2009 | Samsung HL-S5087W 50" HDTV
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
Aug 17, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W shuts off.
the number is 3409-000178
should cost less then $5
Dec 29, 2008 | Samsung DLP HL-P5663W 56" TV
Screen flicker
When you turn off the set listen carefully... If the noise stops abruptly it's the color wheel, if it winds down a bit after you press power off it's a bad fan..
Bill
Dec 01, 2007 | Samsung HL-S5087W 50" HDTV
Samsung HL-S5087W DLP TV Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
