Question about Ovens
Grill & top oven not working on beko dvc663 oven
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
  • 18 Answers
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Posted on Jan 23, 2009
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
heatman101
  • 43501 Answers
SOURCE: Top oven (and Grill) have stopped working
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
  • 417 Answers
SOURCE: Beko dv555w electric cooker.Oven and
Hi
check that the cook mode is set to MANUAL, as if its on AUTO it will not come on.
Posted on Dec 20, 2010
My beko dvc663 main cooker just stopped working no light no fan no oven but everything else works
check this link for a user manual or guide:
http://www.repairclinic.com/shop-for-parts/b121-x62656b6f206476633636332073746f7665/beko-dvc663-stove-kitchenaid-parts
Jan 21, 2015 | Ovens
Beko oven
If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2013 | Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
Beko DV 555w Electric cooker.Oven and clock is not working.
The hob and grill work.
Nov 19, 2010 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
