Question about Neff Dishwashers
Could you please confirm the official size specifications of the Neff S5543X1GB/13?
Neff S5543X1GB/13 - need to know official size spec. Am replacing it with a new dishwasher but want to be sure new one is same size as old one. It appears to be 59.5cm but I need to know its official size - some of those I'm looking at claim to be 59.8/60cm. Thanks.
SOURCE: Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
Posted on Nov 08, 2008
SOURCE: size specs
The measurements are difficult to find and verify. However, you can call Kitchen Aid. They will be able to mail or fax you a copy of the original user manual which should have the specs. The number is: 800-422-1230
Posted on Jan 08, 2009
  • 10865 Answers
SOURCE: Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
Posted on May 21, 2009
  • 8404 Answers
SOURCE: Hello: I'm looking for a dishwasher timer for a
Check with a FixYa.com advertiser or www.repairclinic.com or at your local appliance parts store for your timer.
Thanks for your question @ FixYa.com
Posted on Apr 16, 2011
oldTech2332
  • 2341 Answers
SOURCE: I saw a thread that
Magic Chef was recently sold and the company that bought them no longer publishs online the Magic Chef manuals any longer. However all built in dishwashers are a standard size and any new one will fit in the opoening of a pre-existing one
I'll give you this link http://mcappliance.com/magicchef.aspx and you could try to download the manual but i am 100% sure that all built in d/w's are a standard size
Posted on Aug 21, 2011
V4380X0GB/13
Try Googling (Neff)(V4380X0GB/13)(manual) without parens or contact Neff directly to request the manual.
Jun 07, 2017 | Neff Washing Machines
Torque specs for 2003 saturn veu 3.0
2003 Vue Torque Specs? - SaturnFans.com Forums
www.saturnfans.com > ... > Models > Saturn Vue > Vue Tech
Feb 4, 2009 - 6 posts - ‎5 authors
Does anyone have/know where I can get the torque specs for a Saturn Vue? ... See attached for 2003 2.2 and 3.0 engine torque and front ... need vue torque specs
Oct 13, 2010
Filter cap and drain plug torque spec
Feb 19, 2009
Lug Nut Torque?
Oct 6, 2008
S-Series Torque Specifications
Nov 13, 2004
More results from www.saturnfans.com
Nov 26, 2015 | Saturn Cars & Trucks
Spec's for niigata marine gear model mgy77l-1
www.niigata-power.com/English/products/marine/index.html
Jan 15, 2014 | Progressive Suspension drag Specialties...
The door to my Neff oven is not closing so heat is escaping from the top - please help
You need new hinges use linkhttp://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?Maktx=b1644&eshoptype=A
click on the spares listing for your model (you will need the full Enr from the oven rating plate) and order the hinges (always replace as a pair). Hinges are on page 3 parts list in position 0319 and 0320 (these are not the parts numbers, you need to highlight these positions numbers on the breakdown from your specific model to get the correct part number (six digit part number) You may find that although the position number are different for the left and right the actual part numbers are the same. You can add the items to the basket and order directly from Neff.Hope this helps
Sep 02, 2011 | Neff B1644 Electric Single Oven
No Instruction manuals
Down load them from Neff.
http://www.neff-home.com/uk/service/manual
Then you can print them.
Aug 04, 2017 | Neff Ovens
Looking for installation instructions for a Neff B1691 oven
Neff have some downloadable installation instructions at www.neff.co.uk select neff owners, then customer service, this opens a new window which has instruction manuals as an option, select this and then enter an E number for the model ( i tried B1664) a similar single oven and this brought up a pdf file. At the end p67 it gives cable sizes and types and connection details which should give you what you need.
Please remember to rate this solution.
Dec 08, 2008 | Neff B1691 Single circotherm super...
Colors won't stay set
NOTE: Manual Convergence settings ARE LOST if the customer returns to AUTO Magic Focus mode. (More Details) this situation is normal. Bottom line: This is caused by two issues, The Centering is off of any or all CRTs. (Don't forget Red and Blue Offset values). The Horizontal Size needs to be changed by increasing H. Size by 20mm. Readjust the Horizontal Size to the NEW specifications. These are different that the original Service Manual. They have been increased by 20mm on 51", 57" and by 25mm on the 65". Before replacing DCUs, Please CHECK and confirm if any of the three color center alignments are off and readjust the Horizontal Size to the New specifications.. TO CHECK. Clear DCU data by holding down the DCAM "Service Only Switch" and then POWER. Make sure the Green is centered. Make sure the Red and Blue is offset from center with respective offset value according to the SM information. Readjust the Horizontal Size to the NEW specifications. These are different that the original Service Manual. They have been increased by 20mm on the 51" and the 57" and on the 65" it's increased by 25mm. There IS NO NEED to replace DCUs. The DCUs are not defective...All that is needed is to confirm the Centering Adjustment for the three colors and adjust the Horizontal Size to the NEW specifications. Adjust if any color is found to be out of adjustment specifications. If you don't understand this then you need live chat!
Sep 11, 2007 | Hitachi 43F300 43" Rear Projection...
Dishwashers Logo
49 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
