Question about Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White
Caroma toilet dual flush: push the buttons, nothing happens. The tank is full, but the flushing mechanism suddenly stopped working.
4 Suggested Answers
  • 1206 Answers
SOURCE: Caroma Sydney 305 toilet growls
this is caused by a slight leak in the wax ring causing a gurgle sound, remove it again and reset the wax ring should solve your problem. .
Posted on Jan 26, 2010
  • 760 Answers
SOURCE: Caroma dual flush toilet is only 2 years old and
Try this link for adjustment instsructions:
http://www.caromausa.com/site_assets/www.caromausa.com/images/dynamic/pdf/QuietFlow%202%20Service%20Guide.pdf
Posted on Jul 17, 2010
  • 6 Answers
SOURCE: how do I adjust the
By moving the float
Posted on Oct 25, 2010
Water leaks from tank to bowl all the time
It is most likely the flush valve gasket. This is the equivalent of a flapper on a normal toilet. You can purchase these seals at plumbingmall.com 750017 Outlet Valve Seal for M5 Flush Valve
Aug 06, 2013 | Caroma Sydney Smart 270 Elongated Dual...
Flush mechanism is stuck; unable to push buttons down to flush.
If it's electrical powered, you may have to spray alcohol in the buttons to free them, if urin or other contaminants have gotten behind them to make them stick to were there stuck.
Dec 27, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
I have an EcoQuantum dual flush toilet, all of a sudden it flushes sometimes & sometimes it won't flush at all. I push the handle down/up & nothing happens. Water pressure has not changed at my...
EcoQuantum B8100 is junk in my opinion. There is an obvious design flaw in the handle. The flush/no flush problem lies there. If you contact the company, you can get another handle from them, and problem will be solved. However, it WILL happen again in a year or so, and you will come full circle. Their number is 1-800-391-9821.
Nov 11, 2010 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
Water runs after it fills up?
I am not familiar with that model, but it sounds like your fill valve is leaking or the water level in the tank is too high. Take the toilet tank top off and flush the toilet. When the water gets full and you hear the water stop ( except for your leak) look at the flush valve. Is water running over the top of it and running into the hole in the middle? Then the float need adjustment.
If you are hearing you leak still, lift up on the float. Did it stop? if so the valve may need adjustment due to it not seating completely. You can probably find something online (youtube) easier than I can explain it.
Sep 08, 2010 | Caroma 270W-RF Reflection Round Front...
Water fills tank slowly
Check your angle stop ==valve underneath close to the wall see if it's open all the way if it is and you still have the same problem then go ahead and shut it off, disconnect it from the toilet and the valve and see if there is anything stuck in the hose (a gasket maybe) if nothing blocks the hose then. Reconnect the hose starting from the valve put a bucket on the other side to catch the water and open the valve as if to clean the hose. After you do that reconnect the hose and try again if still does not work properly then you have to replace the fill valve (the tower looking stuff inside the tank)
if it works for you, don't forget to rate me
thx
May 27, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
My V and B toilet suddenly stopped flushing today, what's the problem?
It won't drain? Is the tank draining? Is the water turned off? Or is it just plugged up?
Jun 19, 2009 | Villeroy & Boch 6610 11 Subway...
Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White Logo
Top Caroma Home Experts
john h
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
