Question about Panasonic KX-T7730 Corded Phone
Change ringer tone
I have Panasonic KX-T7730. what are the steps of changing ring tones and selecting different types of rings.
  • 124 Answers
Message/Ringer Lamp: The Message/
Ringer lamp informs you visually that you
have a message or a call.
When you receive a call, the lamp
flashes depending on the ringing pattern.
When the ringing pattern is set to Single
(Slow flash), Double (Moderate flash), or
Triple (Rapid flash) in your PBX, the lamp
flashes. When the other ringing patterns
are set in your PBX, the lamp may not
flash. (e.g., S-Double, Call Waiting
Tone1).
When someone has left you a message,
the lamp is lit continuously.
Please note that the above indicates that ring patterns are set in the the PBX. These are issues that require a real person to sit at the main system and program the features that users need. I hope you have an I.T. person that knows your phone system. If you don't, you'll have to find a communications company in your area that can program your system. Thanks for using Fixya.
Posted on Jan 27, 2009
How to change the ringtone
http://service.us.panasonic.com/OPERMANPDF/KXTGA101.PDF
When you get to ringer settings press select, then using the arrow keys scroll to ringer tone, choose one of the tones or melodies then select save and then select off to get out of the menu you should have chosen a new ring tone.
Jun 05, 2014 | Panasonic KX-TGA101S Cordless Handset
How can we change the ringtone on Panasonic KX-T7730 phone?
You don't. Panasonic analog system phones have one ring tone. You can change the cadence (single double or triple) ring from outside calls, but not the tone.
Carl
Oct 26, 2011 | Panasonic KX-T7730 Corded Phone
How to program ring tone on KX-T7730 for each CO? For example I want the inbound call on CO1 and CO2 to ring differently, and for the call for CO3 not to ring ... thank you !
Analog Panasonic phones have one "ring tone". You program it to ring or not ring, but the tone is exactly the same. Ringing programming is in SYSTEM programming in the 40x's, depending on the cabinet. In a TA series, inbound ringing is program 408 409 and 410.
Carl
Jun 15, 2011 | Panasonic KX-T7730 Corded Phone
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
My office phone have a problem when customer call always complain i dont pick the phone but the problem is i dont hear the ringing tone please help
You can find detailed information about your phone from the given link below.
Panasonic KX-T7730
Check the steps below for "Does not Ring" solution.
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
img%20right%20hand.gif The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | Panasonic KX-T7730 Corded Phone
I want to change the ring voice
you can go to settings and see the options ringer tones, and change
Jun 16, 2009 | Panasonic KX-T7730 Corded Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
How to change ring tone of kx-t7730
sir please i want to when call my consol i'm not there i picup phon our telephone set plz suggest
Jun 16, 2008 | Panasonic KX-T7730 Corded Phone
CHANGING THE RINGTONE
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Press STORE
Press STORE
Mar 20, 2008 | Panasonic KX-T7730 Corded Phone
Ringer
There are a number of ringing patterns which are programmable in the main switch unit, however I can find no information on various ring tones in the manual.........sorry.
Dec 17, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
675 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
