Question about Edimax BR-6226n nLite Wireless Broadband Router
Codice pin 8 cifre router edimax ar-7284wna
Il routr mi chiede il codice pin per la configurazione
3 Suggested Answers
  • 13433 Answers
SOURCE: I have a problem that
Make sure your wireless is protected, if your wireless is open and unprotected anyone nearby will be able to get free internet from you.
Also how have you decided that the problem is your ADSL router? Make sure the wireless is protected with WPA and or turned off entirely if you are connecting with a ethernet cable. then make sure your computer is working OK and your antivirus is up to date, run a full scan with it.
Posted on Nov 27, 2010
  • 109 Answers
SOURCE: I have forgotten my password
Generally all routers have a little button on the back of them where the ethernet ports are that you have to push with a pen for 5seconds that will reset your router to it's factory default settings, this includes any user names and passwords used for an internet connection or any wireless security settings
this will also reset the username and password for logging into the router
Posted on Mar 20, 2011
Can't connect to my edimax ar-7284wna router
theres a temporary solution... reset router and change the date on your computer to 1 febrauary 2010 and you will be able to login. you can set all your details and even if you change your date back to current it will not affect your settings however to log back into the router you need to set back your date to feb 2010..
Hope this works.
May 30, 2012 | Edimax Computers & Internet
OGNI ACCENSIONE (ANCHE SENZA TOGLIERE LE PILE) MI CHIEDE DEL'IMPOSTAZIONE DATA. FACENDO TALE COSA NON SI IMPOSTA NIENTE, PER USARE IL PRODOTTO DEVO FARE OK, LA DATA MI RISULTA SEMPRE DEL 2003.PERCHE' TUTTO...
Ciao Pino.
La Polaroid ha una batteria interna saldata sulla scheda madre (Altre marche e modelli usano una batteria tipo monetina, la Kodak ha una batteria saldata). Questa si ricarica usando le batterie principali. La batteria interna ha una autonomia di diverse ore. Il suo ruolo e' preservare le impostazioni.
Se il problema sussiste anche quando le pile nello slot sono cariche, vuol dire che la mini batteria saldata dentro la camera e' diffettosa, e non mantiene la carica.
Una camera da 5 Mp oggi vale meno di 50 euro. Se la camera funziona non vale la pena ripararla.
Ginko.
Mar 12, 2011 | Polaroid A500 Digital Camera
Come faccio a connetermi a internet
Non parlo italiano, quindi spero che questo viene fuori bene. vai al router Internet della vostra casa. Guardate sul fondo di esso, e dovrebbe avere le lettere "WEP ". Questo ? il codice di sicurezza ? necessario input quando vi chiede per la sicurezza code.Toinizialmente andare e iniziare a creare, andare fino in fondo a sinistra e scorrere verso il basso fino a vedere "Impostazioni di rete". Poi vai a "Infrastructure". Scegliere "Nuova connessione". Quindi selezionare "Scan". Scegli quello con il segnale pi? forte. Questo ? il segnale senza fili della vostra casa. Se lo chiede WEP voce "Sicurezza", immettere il codice WEP sulla tua casella di internet. Se si dice "Nessuno ", quindi basta premere ilpulsante Sinistra sul pad direzionale fino done.The yor unica cosa reale che ti serve ? il codice di sicurezza che la vostra PSP sta chiedendo. Potrebbe non essere WEP. In entrambi i casi, il router internet dovrebbe avere. Spero che questo ti aiuta.
Mar 08, 2011 | Sony PSP-3000 Black Console
No riesco ad entrare sul telephono perche mi chiede sempre il codice ed ho dimenticato il numero
controllare il pacchetto della vostra SIM card.
si dovrebbe trovare alcuni codici di l?.
Ci sono tre codici statici (PIN, PUK, PUK2)
Inserire il codice PIN per accedere al PUK telefono o utilizzare al fine di cancellare il codice PIN
Jan 30, 2011 | Samsung E2210 Cell Phone
Salve ho inserito la chiave di rete nel router belkin che ho acquistato e funziona ma ora ho un problema mentre il pc entra in automatico con il cell. IPhone ogni volta mi chiede la chiave di rete...
non solo emette segnali router Belkin e tutte le reti wireless dipendono da una singola password, controllare il prodotto in modo da poter ottenere Connected
Oct 26, 2010 | Belkin (F5D7230-4) Router (587009)
C max 1600tdci diesel 110 cv anno 2004 errore u0101
certamente il codice indica che non c'? comunicazione tra il cambio automatico e il traction control module o centrallina
controllare il cablaggio e connettori
May 24, 2017 | 2006 Mazda 3
Lettore cd/dvd acer aspire 5630
Ciao,
Allora, ho il tuo stesso pc e mi è già capitato il prob. Mi sè risolto formatando il pc ma non è minca finita qui..
dopo un mesetto mi si ripresentato. La coluzione defintiva è stato quella di sfruttare la mia garanzia per farmene spedire uno nouve di zecca. Ovviamente solo il pezzo guasto.
Se no puoi provare a smontarlo e pulire il lettore dvd con l'alcol (xkè evapora).
Tienimi al corrente per eventuali sviluppi.
Ciao
Jul 18, 2008 | Acer Aspire 5630 Notebook
Edimax BR-6226n nLite Wireless Broadband Router Logo
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
