Question about Dometic Rooftop RV Air Conditioner
Recreational Vehicle A/C
The thermostat keeps going on and off every 30 45 seconds. What could be the cause and is it possible easy fix?
    Scholar:
  • 121 Answers
Check the condenser and evaporator to make sure these are clean. If the filter is not replaced or cleaned regularly the evaporator will become plugged.
If this is a roof top unit the thermostat may have a thermocouple on it that is shoved into the evaporator. Some times these go bad.
Posted on Aug 07, 2008
  • 105 Answers
Air conditioners running into a small space tend to cycle rapidly. Try to direct the airflow away from the intake so that no cold air reenters the unit. This will allow more cooling before the thermostat cycles.
Posted on Jul 15, 2007
SOURCE:
Tip
How to save fuel and make your vehicle last longer, too
Improving fuel economy is easy - just take it easy. It willmake your vehicle last longer, too. Here are some specific tips on how to savemoney on both fuel and repairs.
  • Keep your tires inflated at the correct pressure. Under-inflation causes tire wear and wastes fuel.
  • Do not carry unneeded weight in your vehicle. Excess weight puts a heavier load on the engine, causing greater fuel consumption.
  • Avoid lengthy warm-up idling. Once the engine is running smoothly, begin driving - but gently. Remember, however, that on cold winder days this may take a little longer.
  • Keep automatic transmission selector lever into "D" when engine breaking is not required. Driver with the selector lever in "4" will reduce the fuel economy. (This is referring to vehicles with Automatic drive)
  • Accelerate slowly and smoothly. Avoid jackrabbit starts. Get into the high gear as quickly as possible.
  • Avoid long engine idling. If your have a long wait and you are not in traffic, it is better to turn off the engine and start again later.
  • Avoid engine lugging or over-reversing. Use a gear position suitable for the road on which you are traveling.
  • Avoid continuous speeding up and slowing down. Stop-and-go driving wastes fuel.
  • Avoid unnecessary stopping and braking. Maintain a steady pace. Try to time the traffic signals so you only need to stop as little as possible or take advantage of through streets to avoid traffic lights. Keep a proper distance from other vehicle to avoid sudden breaking. This will also reduce wear on your breaks.
  • Avoid heaving traffic or traffic jams whenever possible.
  • Do not rest your foot on the clutch or break pedal. This causes premature wear, overheating and poor fuel economy.
  • Maintain a moderate speed on high ways. The faster you drive, the greater the fuel consumption. By reducing your speed, you will cut down on fuel consumption.
  • Keep the front wheels in proper alignment. Avoid hitting the curb and slow on rough roads. Improper alignment not only causes faster tire wear, but also puts an extra load on the engine, which, in turn, wastes fuel.
  • Keep the bottom of your vehicle free from mud, etc. This not only lessens weight but also helps prevent corrosion.
  • Keep your vehicle tuned-up and in top shape. A dirty air cleaner, carburetor out of adjustment, improper valve clearance, dirty plugs, dirty oil and grease, breaks not adjusted, etc. all lower engine performance and contribute to poor fuel economy. For longer life of all parts and lower operating costs, keep all maintenance work on schedule, and if you often drive under severe conditions, see that your vehicle receives more frequent maintenance.
Good luck.
on Nov 09, 2010 | Toyota Pickup Cars & Trucks
How do I fix a vehicle that leaks oil
There may be a number of different places leaking, and as one is fixed, the pressure on the other places will increase causing more leaks. Either keep on fixing them until all are covered or sell the vehicle.
Sep 02, 2015 | Cars & Trucks
Engine overheats going up hill, is water pump bad or is thermostat stuck?
I can't answer that question for you without seeing the vehicle, but I can give you another possible cause. It could be that the radiator is plugged.
The thermostat is easy to replace and if you haven't changed it before, it would be a good place to start. If that doesn't solve the problem, have a qualified radiator shop test the radiator for you.
If it doesn't overheat when idling, it's probably not related to the radiator cooling fan, but it's possible.
Mar 06, 2011 | 1997 Mercury Mystique
My 99 ford f150 pu can sit for 30 to 40 min warming up to operating temp then I leave for work and go aproximatley 15 to 20 miles and loose heater then the engine over heats. After a few min it boils over...
Change the thermostat. The thermostat might be opening too late to circulate. From doing so the coolant is just sitting there getting hotter and hotter which would cause overheating until the stuck thermostat decides to open. I would bring the car to a safe temperature and feel the radiator hoses if one is hot and the other isn't? You have a thermostat problem. Easy fix and cheap. I wouldn't run the vehicle too long until you fix it.
Jan 15, 2011 | Ford F-150 Cars & Trucks
Vehicle running hot but coolant is still in the radiator
There are several possible causes. Most likely, the thermostat is not opening fully to allow good coolant flow. A thermostat is cheap and pretty easy to replace, so that is where I would start. Next, make sure the radiator is not clogged.
Aug 05, 2010 | 2002 Jaguar X-Type
What can make my 2002 toyota tamoca over heat
One of the most common reasons for a vehicle overheating is a stuck thermostat. It can stick or freeze in the closed position blocking the flow of coolant to your engine. The easiest way to check if your thermostat is not open is to feel the upper radiator hose. Once the engine warms up it should become warm. If it does not get hot the thermostat is probably not opening.
A second common cause of overheating is a leak in your vehicle's cooling system. If your vehicle is loosing coolant there will not be enough left in the vehicle to keep it cool. This is easy to diagnose as the radiator will be low on fluid and there will probably be a pool of coolant on the floor of your garage. Look for leaks in the most common places like around hoses and around the welds of your radiator. If you can not find the leak you might need to take it to a shop to have the cooling system pressure tested.
The third cause is a faulty water pump. The water pump is a vital part of your cooling system since it is responsible for circulating coolant through your engine. With a faulty water pump your vehicle will not run for more than a few minutes without overheating.
The fourth cause of overheating is a bad cooling fan. There are two types of fans, electric and mechanical. The electric fan should come on automatically once the vehicle reaches operating temperature or when the A/C is turned on. If it doesn't you should have it replaced. The mechanical fan will run all of the time but has a clutch which makes it turn faster when the engine heats up. With the car turned off the fan should not turn too easily especially when the vehicle is warm. You can also check for signs of leakage from the fan clutch. If you see any problems have it replaced.
The fifth cause of overheating I will talk about is a clogged radiator. Over time the radiator can accumulate deposits of rust and debris. This is especially true if radiator fluid has not been flushed on a regular basis. If you suspect a clogged radiator you should take it to a shop to have it professionally cleaned.
Those are some of the most common cause for vehicle overheating. Vehicle overheating can cause a great deal of damage to your vehicle. If you are experiencing trouble be sure to fix your vehicle or take it to a quality mechanic as soon as possible.
Nov 01, 2009 | 2002 Toyota Tacoma
What is the to capacity of a 2006 kia sportage i don't have the owner's manual and want to tow a trailer
Most cars are about 1/2 ton capacity(1000 pounds) Towing a small trailer should be fine as long as the weight at the hitch ball is less than 200 pounds. Load the trailer so the most of the weight is on the trailer not your car.Remember to keep the tire pressure correct on the trailer and your car and give yourself plenty of stopping space as the car will respond slower with the extra weight. Also try to take off kind of slow and easy so you dont over work your cars transmission. An add on type auxillery transmission cooler is recommended.
I hope this info helps you.
Sep 09, 2009 | 2006 Kia Sportage
HEATER NOT HEATING
If your heater is not blowing warm air, your thermostat is probably sticking or your coolant level is critically low. When you start your vehicle, your radiator coolant begins warming up from being cycled through your engine block. One the cooland reaches a certain temperature (usually 130-150 degrees F.), your thermostat spring will retract and allow coolant to then pass into your heater core. However, if your coolant level gets too low, or if you are using a coolant mixture that has more water than antifreeze, thermostats have a tendency to rust and corrode and will stick. Thermostats can also go bad for what seems like no reason at all. The good thing is that usually thermostats are pretty easy to replace. It's the most common thing that would cause the problem that you're explaining. However, if changing the thermostat doesn't fix the issue, there is always the possibility that you could have a collapsed hose somewhere under your hood. If you change your thermostat and none of your hoses are in bad shape, you most likely will have a vacuum line to reconnect under the dash, as most heater controls in late model vehicles are vacuum operated. I'm almost positive that the thermostat will be your culprit though. **Make sure when installing the new thermostat that you use a new gasket or O-ring, whichever applies. Afterwards, start the vehicle and watch to see if you have any leaks around the thermostat housing and continue to observe until the temperature of the vehicle gets to normal operation temperature.
I hope this helps, and hopefully you'll have heat pumping through your vents in no time at all!
Have a great day and try to keep warm!
Nov 23, 2008 | 2000 Jeep Grand Cherokee
Dometic Rooftop RV Air Conditioner Logo
114 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Jay Finke
Jay Finke
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
