Question about Sharp AR-M205 Copier
Ar 5520d error code H4 - Sharp AR-M205 Copier
  • 62 Answers
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Posted on Jul 30, 2008
  • 37 Answers
SOURCE: SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Posted on Mar 01, 2009
007tech
  • 95 Answers
SOURCE: dispays h4 error
An H4 error code indicates trouble in the fusing section - a certain temperature has not been reached within a specified time. It could mean a dirty/bad thermistor or dirty/bad thermostat (both inside the fuser unit. Make sure both of these are clean and there is not debris/paper stuck inside the unit.
You can try resetting the code by : Get into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" then enter 14 and the start key - confirm if requested then make sure the copier restarts.
Hope this helps.
Posted on Apr 18, 2009
  • 7 Answers
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Posted on Jun 10, 2009
  • 3741 Answers
SOURCE: sharp ar-m236 error code H4-21
-H4-21 means: Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch.Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 28, 2009
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Error code H4-01
Error code H4-01 means low temperature.
May 18, 2010 | Sharp AR-M237 Digital Copier
Sharp AR-123E, H4 error code, printer not ready
it doesn`t need to change board. code 14 clears.
May 04, 2010 | Sharp AR-M205 Copier
check both lamps.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
Sharp AR-M205 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
