Question about Electrolux Vacuums
Manual for electrolux diplomat vacuum cleaner
I need the manual to help me change the switch on the cleaner,
SOURCE: Need the manual for this vacuum cleaner
Try this link also
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action
Posted on Jun 14, 2008
reddevil6
  • 1673 Answers
SOURCE: Electrolux diagrams and schematics
Sorry, I don't, but you cn look on line or phone book for Aerus Electrolux. But if they will ive you any info, I don't know. Sorry I couldn't help you out.
Posted on Jun 17, 2008
EwingElect
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
SOURCE: Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Posted on Jul 21, 2009
BElectric
  • 1140 Answers
SOURCE: I am trying to get
I've been trying to get a manual for my mother in law for years ;)
You didn't specify a model number so I'm not sure this is the correct manual, but it is for an Electrolux Vitesse 1600w upright. This manual is for model number Z4703AZ:
http://www.electrolux-ui.com/2007/755/98BEN.pdf
Click the link and the file will open. You can then view, save and/or print the manual. If you are unable to open the file, you may also need to download Adobe Reader:
http://get.adobe.com/reader/
If you have a different model, please post back with your correct model number and I will provide a link for the correct manual:
Please rate this solution if you find it helpful. Thank you.
Posted on Nov 03, 2010
Eletrolux diplomat LX vaccume A72203N dose not start , sine come on FC.what should I do ?
Locate a local vacuum cleaner repair and sales shop in your area and have them look at it.
Jun 16, 2017 | Electrolux Vacuums
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
What do the symbols and dial settings mean on the electrolux diplomat lx
Symbols..Question mark means "Put a bag in me", checkered light means : "Change me, I'm dirty"....pre-lit power light means: "You have Powaaa" to the unit and the thermostat light means the motor is too hot if it comes on, (most likely from a hose clog) and needs to cool down before the motor will run again. The settings on the control valve basically have to do with the auto shutoff when the bag needs changed. The lower the valve is turned, the more full the bag will get until it shuts off. Hope that helps!
Apr 24, 2014 | Electrolux UltraLux 2000 Bagged Canister...
I need the Manual for #2100 Electroluks vacc
Service manuals for the Electrolux vacuums, including the accessories, are only available to the franchise owners and service techs.
Also, having said that, I don't recommend fixing the switch yourself. Replacing the switch involves disassembly of the canister, which is a bit complicated. Putting it back together correctly, without crimping wires. even more so.
I used to be an Electrolux service manager and have seen vacs brought in in pieces. Customers had succeeded in dismantling the machine, but were unable to reassemble it. Or had cracked or broken a piece. This makes the repair more expensive.
Or machines were brought it that had been reassembled incorrectly and wouldn't work. Or worse had shorted out due to crimped or incorrect wiring.
I strongly suggest taking the vacuum to a repair shop that is familiar with the older Electrolux vacuums, in this case the plastic models.
Mar 06, 2014 | Electrolux hose 2100 series diplomat
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux ambassdor will not run after pluggen in
Greeting from GoVacuum,
On all Electrolux canister vacuum cleaners, there is a kill switch, that will not allow the machine to turn on without a bag in it. Sometimes when replacing the bag, the bag is placed in a position where the switch is not being activated.
When you open the bag housing, it should look like this;
You'll notice in the bottom right corner of the bag housing, the kill switch to the vacuum cleaner.
Try plugging the vacuum cleaner in, and while you are pressing this kill switch down, turn on the vacuum cleaner. Does the vacuum cleaner turn on/off when you push/release the kill switch? If it does, simply just get a new bag, and make sure that the new bag is covering the kill switch, and close the door of the vacuum cleaner.
If it still doesn't start, let me know and I'll try to help you diagnosis the machine differently. I'd say that 6 out of 10 times, this kill switch is the problem.
I hope this helps you. Please email me with any questions, or if this fix doesn't make your vacuum work. I really enjoy sharing my passion, and expertise in repairing vacuum cleaners.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 03, 2008 | Electrolux Vacuums
DONT KNOW HOW TO CHANGE MY BELT
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698891
Generic problem for all Vacuums
Posted by mommyhop1 on Jun 23, 2008
I LOST MY MANUAL TO SEE HOW TO CHANGE MY BELT. TRYING TO FIND THE USERS MANUAL FOR MY ELECTROLUX 3500 SR
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the owner’s manual is to contact the Electrolux factory and either download the owners manual from the website or call the customer service phone # and give them the model and serial # of the machine and they will send you out an owners manual for the product. Or you can contact your local vacuum cleaner dealer in your area and they would assist you in changing your belt. Usually there are screws in the bottom of the vacuum and either the bottom will come off or the top cover will lift off and then you can change the belt. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Electrolux Oxygen Remote Control Z5654 Vacuum Cleaner
Check your hose for obstruction. That might be the problem. If not, you will probably need service.
Jan 02, 2008 | Electrolux Z5935 Bagged Canister Vacuum
Vacuums Logo
124 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
