Question about Sony Handycam CCD-TR416 Camcorder
Insert the tape
When i insert a tape the place where u insert the tape shuts but wont go down... it stopped working about 3 months ago and i decided to pull it out and see if i could fix it... the door thing where u insert the 8mm shuts but doesn't go down after it shuts... please help!!
  • Toxictom Jan 15, 2008
    Mine is malfunctioning exactly like yours except it seems to work fine without a tape.
  • 38 Answers
There are a variety of things that can go wrong. The process of elimination starts by taking the 2 screws out of the cover and removing. While the compartment is open, push the eject button and observe if there is any motion with gears or not. The main cam gear should rotate a few degrees in one direction and then back. If you see no motion at all then you have problems that are going to require real work. Most often when this is the situation, this main gear, which doubles as the mode switch, is broken and this is a sophisticated repair to replace.
Posted on Aug 22, 2007
GTA 4 (PS3) wont load
possibly you got the wrong version . we can not fix this for you
Oct 07, 2017 | Rockstar Games Grand Theft Auto™ IV for...
I have a Brother label maker, model number pt65. How do I install the tape. I cant get it to feed through. Thank You
1) Remove the back cover by pressing in on the rough
area at the top end of the machine and pulling off the
back cover.
2) If a tape cassette is already installed, pull it straight out
and remove the paper tab from the new tape cassette.
Make sure that the end of the tape in the new cassette
feeds under the tape guides.
3) Insert the tape cassette, making sure that it clicks into place.
Check that the cassette fits properly around the two
metal guides in the cassette compartment.
4) Attach the back cover by inserting the two hooks on the
bottom end of the back cover into the slots on the bottom
end of the machine, then pushing down firmly on
the cover until it snaps into place.
5) Feed the tape by holding down and pressing ,
then cut the tape by pressing in on the tape cutter button.
The amount of tape remaining is visible through the
window in the back of the P-Touch.
When the usable tape is finished, green ribbon appears
Hope this helps
Bruce
Jun 14, 2011 | Office Equipment & Supplies
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
PLEASE HELP! -- I have now bought 2 Sony DCR-TRV350's. One, I bought originally in 2003 and has worked like a charm up until a few months ago. I have a bunch of old tapes that I never got around to...
Found this post re: Sony C:31 errors
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/Sony_DCR-TRV18_-_Error_Code.
In a nutshell: - Remove tape and close door - Remove all power supplies (battery and AC) - Smack the bottom of the camera hard with your palm - Reattach power supply, insert tape and try again
This solution has worked for me, but problem usually reappears after a few uses.
Dec 09, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Trunk wont pull shut.
You have a pull down switch that activates the pull down motor for the trunk lid to close. The manufacture of this part supplies this to Ford & General Motors vehicles. You can go to a Cadillac dealership & purchase this part far cheaper than at Ford. I use to work at a GM dearlership & my neighboring Ford dealer would order this part from me for the cost of mine where less than the cost from Ford. Figure those guys out at Ford. No wonder they don't need a goverment bailout
Frank
May 22, 2009 | 1996 Lincoln Town Car
Pv-dv53d
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Sony Handycam CCD-TR416 Camcorder Logo
101 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
