Question about Yamaha RX-V471 Receiver
Hi I've received as a gift a dock YDS12 Yamaha for RX-V471 A/V receiver, but unfortunately equipment doesn't has that input in his back. Is there any kind of adapter that allow me connect it to the receiver? Inputs availables are digital, RCA, jack 3,5 mm and USB. Just in case, the link of the YDS12: YDS-12 - Accessories - Audio & Visual - Products - Yamaha United States Thanks in advance
5 Suggested Answers
  • 133 Answers
SOURCE: connect Airport Express to Yamaha RX- V659
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I hope this helps.
Regards
3rq8 (Triarcuate)
Posted on Sep 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: want to use Yamaha rx-797 reciever with bose 901
I don't know why the comment from Yamaha about Tape Monitor killing digital inputs is relevant.
According to the manal I downloaded, THIS stereo receiver doesn't have digital inputs.
As to using 901's and 301's...
You will need a separate Power Amp for either the 901's or the 301's. Sorry, but you can't share the amp with the Active-Equalized signal and non-901's.
I use 901's and 301's in MY 7.1 rig with a separate amp for the 901 and NOT using a Tape Monitor, but a preamp out feed for the front channels.
Posted on Feb 16, 2010
  • 127 Answers
SOURCE: yAMAHA YDS-11 TO A RX-V459
Hi, as per yamaha site RX-V459 doesn't have the DOCK connector which is used by YDS-11 dock (or the bluetooth module). This is the only possibility to connect the YDS-11. YDS nor receiver don't have USB connector and they are not needed.
For example RX-V465 does have DOCK connector and supports YDS-11.
For your receiver, you can use only analog audio cable with your iPod.
Posted on Mar 02, 2010
  • 127 Answers
SOURCE: I have a Yamaha RX-V465
Yes, it is compatible.
http://usa.yamaha.com/products/audio-visual/accessories/yds-12_black__u/?mode=model
It has 2 modes of operation. For RX-V465 you need to select mode B. In this mode it is compatible with YDS-11, which is supported for RX-V465. But iPhone is not officially supported in this mode. But I have found on Yamaha website FAQ, where they claim that iPhone switched to Airplane mode worked well.
http://faq.yamaha.com/us/en/article/audio-visual/accessories/yds-12_black__u/4742/4061
Posted on Jan 28, 2011
How do i connect my JVC screen tv so that i can hear out of my speakers
If your JVC TV has AUDIO OUT outputs on the rear and a provision in the initial set up screen to disable the internal speakers, you can connect to your Yamaha receiver and enjoy improved sound.
Dec 14, 2014 | Yamaha RX-V471 Receiver
Yamaha RX-V471 3D video for blu ray will not display on TV
Your Yamaha is the problem here. It cannot handle the signal and process the 3D as it states. What I would do is hook your player direct to your TV in the manner that it works and feed your audio from a different path to maintain surround system. Your tv/dvd player may have an audio out that you can feed back to the Yamaha .
Jan 11, 2014 | Yamaha Rx-v471 3D A/v Receiver
Can not change volume
You have a Rotary Encoder, not a volume control. It functions as an input to a microprocessor(computer within your receiver). The encoder shouldn't effect the remote control. If that doesn't work either, the microprocessor is probably bad. If you require more assistance, or would like to inquire about repairing your Yamaha, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jan 04, 2014 | Yamaha RX-V471 Receiver
Want to know if it is possible to hear a record player through the AUX plug out? since my Yamaha RX-V396 receiver doesn't have a phono plug out
hi,
Only you can hear the record player through the aux of your amp if the record player comes with built in phono preamp. If not you need a phono preamp between the record player and amp or an amp which have a phono input. Phono preamp is available in the open market.
ok
May 22, 2011 | Yamaha RX-V396 Receiver
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
YAMAHA YDS-11 TO A RX-V459
Dec 17, 2009 | Yamaha RX-V459 Receiver
Ipod connection to a Yamaha RX v363 receiver
Fortunately you are wrong :)
On yamaha site you can see that RX-V363 has a DOCK connector, which supports both iPod docking station YDS-11 and Bluetooth Wireless Audio Receiver YBA-10.
Jan 25, 2009 | Yamaha RX-V1800
Yamaha RX-V471 Receiver Logo
56 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
