Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
After replacing stator is there a break in period
I have a 05 rmk 900 and i just had the stator and the flywheel replaced and now my sled runs like s**t. when i start it it will start but the lights and the gauges all flash on off on off wont stay on unless on the throttle. need some help cost me 958 dollars to get the stator and fly wheel installed at polaris and really dont want to take it in again
4 Suggested Answers
heimlich
  • 1978 Answers
SOURCE: 1997 Polaris rmk 700 has no spark. Kill switch is
try bypassing the kill switch and the ignition switch. Often the switches fail before the other components. the ignition can usually be bypasses by simply unplugging it from the harness. You may have to loop the wires to bypass the kill switch.
Posted on Jan 29, 2011
SOURCE: 2005 POLARIS RMK RUNNING PROBLEMS
Check all electrical connections
Posted on Feb 17, 2011
5keepers541
  • 3498 Answers
SOURCE: How do you flush cooling system on a polaris pro rmk?
There are two "recommended" methods.. both are used...
1. Stuff a 1/2" hose down the coolant bottle and siphon it out. Then remove the bottom hose and repeat the process.
Cleanest way i've found.
2. From Canada: Take your wet/dry shop vac. clean it really good. crack the hose connection at the head and thermostat while you hold the end of the shop vac there, and it will suck out all the coolant, and no mess in the engine bay.
Posted on Jun 12, 2017
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Why would my Polaris snowmobile overheat?
My sled overheated - HCS Snowmobile Forums
www.hardcoresledder.com > ... > Rush/Switchback (Pro-Ride Chassis)
Jan 6, 2013 - 12 posts - ‎3 authors
Hey guys, I was out riding my sled yesterday, and out of no where, it threw a code, and it went into limp ... I would be worried about where did the coolant go? ... (Knowledge + results / corrected HP)Polaris + Als input = WGAF ... overheating
Feb 23, 2013
05 Polaris Switchback 800 overheated
Dec 23, 2010
Overheating...
Dec 23, 2008
2001 xc 600 overheating
Nov 29, 2006
More results from www.hardcoresledder.com
02 800 rmk overheating - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris-snowmobiles/67778-02-800-rmk-o...
Mar 4, 2012 - Does anyone know where I can get free service manuals for my sled so ... for a 05 polaris edge touring but i have used it to fix my 02 edge 600. Edge 600 overheating
Jan 2, 2013
Snowmobile Overheat Problem :( F8 LXR
Jan 16, 2012
2000 touring 600 overheating
Jan 13, 2011
need help with overheating issue
Nov 20, 2005
More results from www.snowmobileforum.com
800 Pro RMK, overheating, coolers... a
Jan 01, 2016 | Winter Sports
Katemjohnson26@yahoo.com
Sounds like you may have gotten some water in your gas. Flush thetank.
Feb 14, 2014 | Arctic Cat F6 Firecat EFI Winter Sports
2004 900 efi mountain cat no start, seems like no spark
try unplugging the throttle switch to see if its ok. then of course replace...thats a quick sled
Sep 01, 2017 | Arctic Cars & Trucks
Reverse on my 2007 rmk is going into reverse on its own and toggling back and forth from fwrd to rverse winthen seconds wat shuold i be checking ?
My 07 RMK 600 did the exact same thing after a VERY wet ride on the sled deck. after i let it dry out it, then next trip we made it seemed to run fine.
were you able to identify the problem on your 07 RMK?
Jan 31, 2011 | Polaris New Genuine Polaris Snowmobile...
900 rmk going down trail and died No spark now
CDI box went out, or your stator poped. only things posssible, coils dont go out at the same time
Jan 25, 2010 | Polaris New Genuine Polaris Snowmobile...
I was full throttle going across a lake when boom the snowmobile stalled and dropped down. I opened the hood and the primary clutch was in 3 pieces and the belt was in pieces. Tell me what it would have...
those 900s had a recal for many things, one of which was very poor cooling to the clutches, they recalled them and put aftermarket vent kits, your clutches got really really hot and came apart
Dec 17, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
37 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
