STAINED WHITE T-SHIRTS, DULL LINEN
I have noticed that if you hold the white t-shirts up to the light the exact pattern of the inside drum has sort of emprinted dull stains on the shirts and my white linen is no longer white anymore
  • slhoward82 Jan 19, 2009
    My washer does this also. It ruins every white or pastel shirt I own. I also can't get my whites white no matter the detergent or bleach that I use. I hate this.
Hi! I am a habitual cleaning type person and clean clothes rate at the top of my list. I have 4 recommendations that SHOULD help tremendously for ALL your clothes but is most evident in your whites.
#1 is the right washer. I NEVER knew how clean my clothes could come out till the past year and a half I finally bought front loader. And let me tell you was I ever surprised at how clean and soft they were, LIKE NEW! Those old top loaders,even the new ones are no comparison to the front loading systems. BUT expensive if you have to go out and buy a new one BUT also a GOOD excuse to tell hubby you need a new one...LOL
#2 Always use liquid detergents, they seem to wash and rinse out so much better than any powder
#3 A HUGE helping hand I discovered some 30 years back that I STILL have not found that can be beat is "BIZ" bleach. It's miraculous! It's a great pre-treater to soak badly needed whites in and helps to retain bright colors if used in non-white laundry. Actually I even use it in a powder form. AFter loading all my clothes in m y front loader I scoop out a cup and actually scatter it OVER my laundry. Then add the liquid detergent (Tide or the like, I get mine at Costco or Sam's club depending on what region you live in) and wash like normal.
#4 Last but not least, for whites and ALL colors I have found nothing better than DAWN dish washing liquid. Immediately pre-treat ANY stain no matter the size with Dawn and just fold it over and toss it in the laundry. Best if washed within the same week at the latest.
GOOD LUCK to all you Domestic Goddesses! ;-)~
Posted on Feb 01, 2009
Where are Sunday work clothes mens t shirts?
Personally, I have not seen such shirts. There are some listed for sale on www.kijiji.ca
Jan 04, 2014 | The Shirt Factory Men T Shirt SUNDAY WORK...
What are the common patterns found on Hawaiian shirts?
The authentic Hawaiian or aloha shirts are decorated with traditional Hawaiian quilt designs, tapa designs, and floral patterns in muted colors.
Feb 28, 2013 | Clothing
How do i set color on tie dyed t-shirt? color is running each time i try washing it
my mam told me to steep them in salty water before puting into wash old wives tail but it worked for me but most home dyed stuff the colour will run hope this helps ivan
Sep 28, 2012 | Washing Machines
I've been noticing what appears to be a rust stain on white shirts that come out of a Kenmore 3t front loading dryer. They are all the same shape, a 3 inch stripe.
i would inspect the drum, and take some white towels soak them in bleach, wring them out and run them through a cycle and see if that cleans it up. Hope This helps Tim
Oct 24, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
White shirts have grayish stains
try soaking the shirt with ritz's white dye.
Sep 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Washing leaves spots in dress shirts
What you could possibly try, is run an empty load, to wash the washer drum clean of sediment. If the washing macine drum is stained, clean it by hand with a cleaning compund, like clorox or some other kind of cleaning solution. Another thing that you can try, is to use the dish washer cleaning solution that they sell, to clean dish washers of sediment. It comes in a small white, plastic square container and Walmart sells it.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag electric dryer makes noise from heating compartment--sounds like fan blades maybe hitting something?
I don't know that I can help you in any way other than to say that you are probably right. But some times the blower wheels do come loose and spin somewhat freely on the shaft and make a similar noise. But when that happens, you will usually notice a vibrating sound right after the drum stops spinning. Because the blower wheel continues to spin for a second or two. But I have seen, popsicle sticks, jewelry, bobby pins,those plastic white things that are under the collar in shirts and all sorts of other things in those blower wheels making noise.
Good luck
Jul 27, 2008 | Maytag Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Washing Machines Logo
192 people viewed this question
Top Washing Machines Experts
