Question about GE 30 in. Profile JP989 Electric Cooktop
Front burner on electric G.E. cook top not working
5 Suggested Answers
  • 213 Answers
SOURCE: We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Posted on Nov 22, 2007
  • 1214 Answers
SOURCE: GE profile performance electric cook
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Posted on Jan 23, 2009
  • 457 Answers
SOURCE: I have a GE 30 inch electric cook top. 2 days ago
sounds like the heater coil is defective or switch is bad. service tech is needed for this. components has to be checkjed properly.
Posted on Feb 24, 2010
Testimonial: "Thanks, This tip was very helpful."
heatman101
  • 43501 Answers
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
Kitchen aid KECC507GBL3 electric 36in cooktop. Burner switch is out - cannot get glass top off. Have removed all screws from plate mountings on the sides. Is there a trick to this?
If it’s a range, there is usually a couple of screws that hold the front of the top down, remove the screws, lift the front of the top and pull it out from the back hinges. Install the new top, make sure there are no loose wiring.
If it’s a cook top then make sure that the power to the cook top has been turned off, open the cabinet and look up. There should be a couple of brackets that secure the cook top. Remove the brackets, carefully lift the top and set it on the counter top (put a towel on the counter top first). replace the glass top (make sure there is no loose or exposed wiring), set the cook top back in the counter, secure it with brackets as was before, and double check your work.
Thanks for contacting fixya.com
Jan 14, 2010 | KitchenAid Cooktops
Red light on cook top remains on always.
Don't really need a wiring diagram, although there may be one inside switch area. (make sure to put it back again if it is there) Will need the full model number to get you the part number you need. (model number usually on a sticker near where the electrical wire enters the cook top)
Turn off power to cook top. Open cover to switches. Pull two "pilot" (usually smaller spade terminals) off the switch for the right front burner, and insulate each with a bit of electrical tape. Turn power back on to see if light now off. If yes, replace that switch. If no, replace those wires and repeat procedure with the next switch until you find the bad switch. Send a comment if you need additional help.
Feb 13, 2009 | GE 30 in. JP326 Electric Cooktop
GE profile performance electric cook top is not producing enough heat in the front burners.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Cook top "popping" noise
make sure the heater elements are properly nested into their respective electrical sockets. if they get loose, then the electrical contact can be intermittent and arc/spark a bit..
Sep 10, 2008 | Kenmore 30 in. 44022 / 44029 Electric...
Wearing burner
no fix other than replacing the cook top with a new one
May 05, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn Air gas cooktop
pop me an email at b4829@yahoo.com and reference your cook top you can rate me later
Mar 29, 2008 | Cooktops
GE 30 in. Profile JP989 Electric Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
