Question about Akai Televison & Video
I need a code for my tomtec DVTV 1928W for a philps universal remote
I have a universel remote controler from philips but i need the code from tomtec
SOURCE: i need codes for philips universal remote control
http://www.lexrixa.com/vcr%20codes.pdf
Some kind soul scanned the code book.
Posted on Feb 02, 2008
aprmaejun
  • 97 Answers
SOURCE: philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
Posted on Jun 21, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
  • 5 Answers
SOURCE: activate RCA Universel Remote with Ascent
this may work for all universal remotes, im using the philips SRU3003/27 universal remote. it doesnt contain a code for my t.v., however after searching the internet n all that. i was able to program my tv. and heres how 1: Manually turn on ur tv 2:hold setup untill red indicator stays on and release button 3: press and quickly release what you wanna program (i.e tv,vcr,ect.) 4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again. 5: press and release MUTE to install the code. i hope this helps for all those who have had to deal with these nice but annoying tv.s
Posted on Jul 17, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
Phillips remote code to emerson
Guessing you mean Emerson TV. Try 002, 003, 004, 005, 104, 105, 106, 115, 204, 205, 206, 213, 304, 305, 316, 319, 405, 502, 505, 506, 519, 604, 605, 705, 804, 805, 903, 904, 905, or 906. If you have a Philps universal remote, you also can try code search.
Apr 21, 2014 | Philips Televison & Video
I need a code for my tomtec DVTV 1528W for a Thomson universal remote control ROC 4238
0123 0378. Try these codes.If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls.See it in "Mosaic" view.It will make surf easier.
http://electrohelponline.blogspot.com/
Feb 10, 2014 | Akai Televison & Video
CODES FOR A MAGNAVOX TV
Try 002, 009, 109, 118, 209, 309, 402, 408, 502, 508, 510, 807, 914, or 917
Dec 02, 2012 | Philips SRU3003WM/17 Universal Remote...
Code for one for all remote urc11-1660
At last count Philips had over 20 different codes in use, many of which universals will not have. Some remotes will not program for all sets.
Nov 03, 2012 | Televison & Video
Hello i cannot find the code number for my philips remote control number srp5004/86 the one in the manual does not seem to work. is there any chance you can help. my tv is a philps lcd thankyou
0330, 0430,0036,0136,0738, 0439, 0807,0022,0020,0422,0122,0222,0322,0002,0520,0919,0521,0621,0430, 0247, 0901,0402, 0408, 0109
Here are some codes for a philips I hope it helps you. Let me know kkarenfaith@aol.com
Feb 04, 2011 | RCA 3-Device Universal Remote with...
I have a philps universal sru 3003 and i need the
1st, grab the remote control with your right hand, then stab it into your right eye socket as hard as you can. If you are not bleeding, repeat this step until you are unconcious and unable to think about how frustrated you are at not being able to find the answers you desperately need online.
Jan 21, 2010 | Philips Televison & Video
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
Philps Universal cl034 needing codes
i need the tv code(toshiba tv) for my phillips universal remote control model CL034
Dec 28, 2007 | Philips RC2573 Remote Control
Televison & Video Logo
78 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
