I want to ask about ricoh 3045 , 901 sc plz
Copier 3045 ricoh , 901 sc
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
munybuny
  • 14 Answers
SOURCE: Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Posted on May 20, 2008
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
NALDZ
  • 38 Answers
SOURCE: Functional Problem with RICOH Copier Error No-SC:541
YOU NEED TO RESET THAT CODE
Posted on Oct 22, 2008
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 1035 sc code sc 329 troubleshooting
Laser diode beam not positioned correctly. Turn the machine off and back on and see if it goes away. You can run sp 2109-3 or 2109-4 in the service mode to adjust the beam in service mode by pressing on the yellow button. pressing the 107 keys and holding down on the clear button.
If this doesn't resolve the issue, you probably need a laser which we have one for sale here.
Posted on Dec 17, 2008
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Ricoh mp 2550b sc 995 solution
SC995 Serial Number Setting Incorrect The 11-digit serial number is printed on the data plate. This information is compared with the installed components to detect mismatches. Did you remove any of the machine parts or components? Reinstall anything you removed and see if the error is resolved. If it's a problem with the NVRam, you'll need to contact an expert.
Dec 02, 2014 | Ricoh RICMP2550B Aficio Mp2550B - Digital...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Plz tell me code solution Ricoh Aficio 2045 is problem sc 303 code
That is an error in the yellow drum charging unit.
You can have an arching yellow charge, a bad contact, etc.
It is the high voltage portion of the yellow drum unit.
Nov 10, 2010 | Ricoh Office Equipment & Supplies
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Hi sir iI have an copier ( aficio 650 ) with error code ( sc 401-2 ) I ried to change the transfer unite , mother board , and power supply . the same sc code is appear againe while coping . plz send me a...
Did you change the power pack?
Check the connectors and connection between transfer belt unit and high voltage board.
Also make sure the machine is clean (near HV board and transfer )
Feb 25, 2010 | Ricoh Office Equipment & Supplies
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Service call sc:543 for Ricoh Aficio 1515mf
plz do like this after again it shwos same then need to replace parts thermister,and thermal fuses. press the yellow 107 red and hold the red for two mints it shows copy sp.......like switch off on
Mar 25, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
78 people viewed this question
jasbo
jasbo
