An error L4 for sharp ar-203e. How can i fix it. Pleas help me...
Hello sir, i have a copier machine sharp ar203 erroe l4 how to reseat can you help me
Posted on Jun 04, 2013
Sharp ar203e
l4 32
what can i do
Posted on Jan 04, 2013
  • 87 Answers
SOURCE: Error L4
l4 if sub code is 01 .check sub code by pressing start key .that is for main drive motor and gears .just check all main drive properly mian jee
Posted on Jan 21, 2009
  • 120 Answers
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Posted on Jul 09, 2009
xptareq2000
  • 1447 Answers
SOURCE: error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Posted on Dec 16, 2009
SOURCE: Error L4
somebody know how to enter the diagnost mode in Xerox document centre 555 it's urgent
Posted on May 05, 2010
  • 47 Answers
SOURCE: L4 Error on SHarp AR 5316E
did you try changng the toner?
Posted on Jun 02, 2010
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
Sharp AR-203E
Hi again Ali, The link below is a free 39 page user manual for a Sharp AR-203E I thought you might be interested in.......CHEERS..
http://www.sharp.co.uk/cps/rde/xbcr/documents/documents/om/34_ppc/AR203E_OM_Online-Manual_GB.pdf
Apr 03, 2016 | Sharp Office Equipment & Supplies
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Installer of sharp AR-203E copier, scanner, printer
You can download driver software for your sharp AR-203 from here http://sharp-ar-203e-series-mfp-driver.software.informer.com/download/ Hope this helps,
Please rate if this solution was helpful, thanks!
Jul 19, 2011 | Computers & Internet
Error code H4 sharp AR-203E
plz help me my prenter sharp ar203e h4 error plzzzz
923002503009
tofiqueali.ss@gmail.com
Oct 09, 2010 | Sharp Office Equipment & Supplies
My sharp AR-203E photcopier is flashing a number then what appears to be the letter H, it had a paper jam but thats now sorted but it wont do anything!! help
on the control panel press clear button then interrupt button then zero button then interrupt button the display will change, then press 1 then 4 then start button then clear button (or power off) if you are blinking H then 5 it means you have had several jams in the fuser
Jan 07, 2010 | Sharp Office Equipment & Supplies
Error code L4 30
Dec 16, 2009 | Sharp AR-M455N Copier
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
515 people viewed this question
jasbo
jasbo
