Question about Fujitsu LifeBook AH530 NoteBook
No scrolling on fujitsu ah530
For some reason I can't figure out how to get my laptop to scroll at all, it just moves the mouse which is very annoying
pontelemon
  • 531 Answers
SOURCE: My Fujitsu Lifebook is stuck in some sort of
Disconnect keyboard.
See if it's going to stop scrolling.
Posted on May 26, 2010
puku_07
  • 60 Answers
SOURCE: My Laptop: Fujitsu LifeBook A Series, A6110 is
Contact Your Dealer or
If you are able to repair your notebook so try cleaning RAM.
It may solve your problem
Posted on Jun 29, 2010
djredskyy
  • 670 Answers
SOURCE: fujitsu laptop is not displaying
does it give you any error? and is it a new notebook?
Posted on May 09, 2011
joelwilcox
  • 1274 Answers
SOURCE: The internal microphone is missing from my Fujitsu AH530. Is there one?
yes there should be an internal microphone, what do you mean it's missing?
Posted on Apr 27, 2012
SOURCE: Built-In Microphone Doesn't Work.
microphone or wi-fi
Posted on Aug 24, 2012
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
My touch scroll stopped working for my Gateway NV53A. Can I fix it?
1_9_2013_6_10_09_am.jpeg check it first , by , connect a mouse , go control panel disable it , and use mouse ,turn the notebook , turn on & enable it , may be works , other wise hardware problem.
Jan 09, 2013 | Gateway Computers & Internet
How to scroll with touchpad on hp g72
Go to:
Control Panel -> Mouse
click there ' Device Settings ' tab. Choose ' Synaptics TouchPad ' and little lower click on ' Settings... '. From the list which will be there select ' Scrolling ' -> ' One - Finger Scrolling ' and uncheck (if they are checked):
  • Enable vertical scrolling
  • Enable horizontal scrolling.
Click ' OK' .
original?v=mpbl-1&px=-1
Next go to:
click there ' Device Settings ' tab. Choose ' Synaptics TouchPad ' and little lower click on ' Settings... '. From the list which will be there select ' Scrolling ' -> ' Two - Finger Scrolling ' and uncheck (if they are checked):
Click ' OK' .
Make it easier for other people to find solutions, by marking my answer with "Accept as Solution" if it solves your issue.
Regards
Nanda Kishore Reddy
Hitech Systems, Nellore
Jun 06, 2012 | HEWLETT-PACKARD G72250US Laptop
Apr 26, 2012 | Fujitsu Computers & Internet
Release the scroll key
    • 1 Open and power on the laptop.
    • 2 Wait for the laptop to fully boot.
    • 3 Locate the "Scroll" button at the top-left of the keyboard. It is under the volume panel and between the "F12" and "Pause" keys.
    • 4 Press the "Scroll" button.
    • 5 Test it by opening a spreadsheet and using the arrow keys to move around on it. You can open your Microsoft Excel program or create a spreadsheet online by using Google Docs (free online productivity software). The "Scroll Lock" function will keep the current cell selected while the screen moves.
    • 6 Press "Scroll Lock" again to turn it off.
Apr 17, 2012 | Logitech Cordless Desktop MX3200 Keyboard...
May 26, 2010 | Fujitsu LifeBook N3520 Notebook
Mouse scroll wheel doesn't work properly
have you tried clicking on the bar that moves the page left to right and then tried using the scroll wheel?
Sep 19, 2008 | Microsoft Wireless IntelliMouse Explorer
Turn off scroll button
hold down the fn key and press the scroll button.
Oct 11, 2007 | HP Compaq Evo Notebook N115 (470035-737)...
Fujitsu LifeBook AH530 NoteBook Logo
26 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
