Question about HP Nx6310 Notebook
Hard drives not detected in my hp compaq nx6310....
Whenever i start win xp installation i fail.. as system shows a error message tht setup is not able to detect any hard drive on your system..
help me....
    Scholar:
  • 80 Answers
Dear, in all the new laptop's its common problem because what bootable cd u are using did not contain sata drivers and thats why it shows no harddrive found ok so search the sata drivers and make bootable cd by adding this sata drivers and than try to boot.
Posted on Jan 19, 2009
My nx 6310 doesn't detect hard drive on xp installtion
Posted on Apr 15, 2010
    Problem Solver:
  • 82 Answers
When u boot the pc see there is key on keyboard pause press pause button & check at the boot whether
ur hardisk is shown in the list/ even cdrom is also shown & if not then ur hardisk is faulty showthis
to ur local service center...................... Sameeraryan
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
Hi, I have a HP NX6310 notebook with Win Xp Pro installed. I need to reformat it after it was heavily virused, and reinstall Win Xp but without the recovery disks I am rather helpless. The recovery...
You can't see any HDD's when trying to install because your BIOS system was set the IDE controller to an AHCI, you can set this to native IDE and windows XP setup will read a HDD's..
If you need set the IDE controller to AHCI you need Intel AHCI controller driver for your system, you can see it during installation process to press F6, you must use floppy diskette and put the driver onto it.
Another way to install AHCI driver is Integrate the driver into Windows Installation directory..See here for more details..
Aug 10, 2011 | HP Compaq nx6310 Notebook
Whenever i want to install win xp sp2. it shows me error message. i'm unable to install. but compaq recomends windows 7. So how can i do this?
go to bios setup and change the type of your disk drive from SATA to IDE and it should be installed..
Jul 22, 2011 | Computers & Internet
Can't install xp
Are you receiving any error messages when you try to install Windows XP?
If it is not detecting your Hard Disk follow the steps below:
Go into the BIOS setup (press f10 during boot process), System configuration and disable SATA Native Support. Try installing XP again and it should see your hard drive.
May 18, 2010 | Compaq Presario 700 470024-192 Notebook
My HP compaq dx2450 can't install Windows XP. I tried with many diferent versions (most of them were speciffied to work with AMD 64-bit processors), but allways recieving same message (insert sistem disc)....
make sure to use a bootable win xp setup disc
and the message (insert system disc) means that the system was unable to find a boot sector ie the hard disk or the xp setup disc
Jul 09, 2009 | HP Hewlett Packard Compaq Business Desktop...
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
When installing win xp from CD an error message says: no hard drives found
Just check that the hard disk is installed properly or not by checking its all cable.
If hard disk is detected then goto the bios option by pressing "DEL" or "F2" button as per your system configuration and then just find the : Native SATA support and disable it. After this save it by pressing shortcut key i.e. F10 and restart our machine.
After this start your XP setup.
Mar 03, 2009 | HP Workstation Xw8000 PC Desktop
Hp compaq presario v3000 is not loding the OS, show an error
  • as you boot the computer, start tapping the F8 keys
  • From the boot menu, select Safe Mode
If this seems to work, you can try restoring the computer to an earlier point from Start > All Programs > Accessories > System Tools > System Restore.
If Safe Mode also fails to load, you would have to check your disk for errors or you may have to install XP all over again.
Please get back, if you need any further help.
Jan 09, 2009 | HP Compaq Presario SR1920NX PC Desktop
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
HP Nx6310 Notebook Logo
447 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
