Question about Refrigerators
Door of a refrigerator has a week magnetic strip all around it. why
5 Suggested Answers
debihendrick
SOURCE: Sub-zero Refrigerator Door
We have the same problem and were told to apply vaseline to the rubber edges of the door; this did help.
Posted on Sep 27, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore 596.50692000 refrigerator.
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Let me know if this helps, Thanks, Sea Breeze
Posted on Mar 26, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Door on refrigerator won't close and stay closed.
You will need to replace the gasket. The gasket seems to have failed and that is where the magnet is. You can try to clean the magnet surface and the door surface with rubbing alcohol but you are most likely going to need to replace the gasket
Posted on Apr 28, 2009
heavyice
  • 374 Answers
SOURCE: I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door itself...you see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Posted on Jun 05, 2009
Old whirlpool upright freezer. door left slightly ajar.light on inside. Rubber around door warm. won't seal.some things starting to thaw.shut door.should I do anything else
Seal needs to be replaced around door. Make sure magnetic strip is tight against sides of refrigerator, even if you have to cut the outside so it lays flat against the sides.
May 03, 2015 | Whirlpool Freezers
GE fridge magnetic strip in right hand door needs to be re-installed, how can i do that?
The magnetic strip (very dark brown) is usually embedded inside a similar square hollow tube all the way around the door gasket. For it to have come out, there has to be a cut, slice or hole in the outer coating of the gasket. Press all the way around the gasket and you should feel the hollow spot where the gasket came out. It will feel solid where the magnetic strip is still in there.
Apr 04, 2015 | GE Refrigerators
What is a magnetic seal on a refrigerator door?
Its strips of magnet on the parts of the door and the part of the inner frame of the fridge that hold the door sealed with magnets nice tight seal.
Sep 05, 2014 | Amana Refrigerators
My Neff fridge (K4316X1/GB) door does not close tightly on it's own and so does not seal properly unless I press it home
Try the following:
  1. Make sure there is nothing sticking out the fridge what could keep the door from shutting;
  2. Take a good look at the hinges and perhaps clean them or lubricate them (using Teflon spray);
  3. There is a white rubber strip all around containing the magnet with which the door should seal itself. Clean this rubber strip and the surface of the fridge it lands on;
  4. Make sure the fridge is level.
May 31, 2014 | Neff K4664 Top Freezer Refrigerator
How to you replace the freezer door seal
is it a latched door, if so weather stripping (high density foam) is a good alternative, commonly used on edges of doors, believe it or not that is a door seal just without the cover to make it more pleasing to look at, it comes in various depths, sizes and is normally two sides adhesive. if it is a magnet strip type; pick a side and use it as a strip magnet surface or cover it.
Oct 14, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
Refridgerator door shutting causes freezer door to open
Check for a draft connecting main body to freezer body, theory is air compression transfer from main compartment to the (smaller) freezer compartment. also a quick fix would be to add more magnet strip or bare the metal that makes contact to the magnet strip that seals the door, if its a latch, Inspect the surface area that locks the latch to mount. Draft checking is achieved by blowing a fan into the smaller compartment, vice versa and having strands of string hanging around in the opposite compartment, if the string nudge indicates an air passage point. Also, check the level of the fridge, if the fridge is uneven (assuming the front is tilted downward) the momentum of the door closing will push the fridge backwards and whip it forward effectively opening the freezer door.
Oct 14, 2011 | Refrigerators
Doors won't close independantly. Magnetic "strips " hit and freezer or frige stays open slightly
Has the unit recently been moved or the doors removed at any time? Either the door are not aligned or they are damaged around the hinges some how. I would adjust doors from the top of the unit, assure not product (food) could obstruct the door from closing. Lastly double check closer at the bottom, this is a two piece system and I had seen this come apart recently.
I hope this helps
Aug 11, 2011 | GE GSS25LGM Side by Side Refrigerator
The fridge door will not stay shut. It is noticeably lower than the freezer-side door. We think there may have been too many condiments in the door pulling it down. Also, on the freezer door, there is a...
ON THE REFRIG DOOR LOWER HINGE, CHECK THE CONDITION OF THE CAM UPPER AND LOWER HALVES. ALSO YOU SHOULDN'T SEE ANY BLACK MAGNET ON A DOOR SEAL UNLESS IT'S BAD.
Oct 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
Kenmore 596.50692000 refrigerator. Every time I shut the refrigerator door, the freezer door pop open. What can I do? Do I need to replace the magnetic strip around the door? Who can give me instructions?...
Mar 25, 2009 | Kenmore Refrigerators
Refrigerator
use a hair dryer to heat the gasket up and gently pull all the bends and wrinkles outs. this takes a tremindous amount of patients even with us techs, so work slowly. once you have that done and the gasket shift to form the door seal put a light coat of vasaline all the way aroung the gasket then push the door shut making sure you gasket is touching the door seal all the way around it mat take going over it again with the hair dryer with the door closed to get it to form correctly, once formed don't open the door for a min. of 4 to 8hrs if it can be avoided and after that make sure you close the door and it seals for the next week to 2 weeks which is about the time it take for it to cure properly
Jun 13, 2008 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
