Question about Delta Saws
How do I chage belts on Delta RT-31 table saw
stug_57u
  • 99 Answers
SOURCE: delta table saw
The reset button is normally a thermal overload, using a bio-metallic strip to break the circuit. If it is old or has popped a few times it might have 'weakened' abit. Try replacing the thermal/reset button. If it still happens then something might be overheating and causing the problem.
Posted on Nov 01, 2008
  • 86 Answers
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Posted on Mar 22, 2009
efs_perpends
  • 1996 Answers
SOURCE: I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
Posted on Mar 31, 2009
spekgt
  • 60 Answers
SOURCE: Where do I find a replacement motor for a 1313314
Hi there
You can try the website @ http://www.deltaportercable.com/ to see parts list and find service centers near you .
Delta , Porter Cable and Dewalt are together so you can get parts thru Dewalt parts center .
Hope this help
Posted on Aug 31, 2009
VtToolMan
  • 704 Answers
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
Is it safe to install the delta invicta rt.40 table saw on a mobile stand
Yes. They even make mobile stands for Unisaws.
Just make sure that once the saw is positioned where you want to use it, it isn't still movable. You have to buy a mobile stand designed for table saws that lifts the wheels up or pushes feet down when you're not moving it...Or you can make one! Check out woodworking videos on YouTube on the subject.
Oct 16, 2014 | Delta Invicta Rt 40 Table Saw
How to install;drive belt on model 34-670 saw ?
You must lower the motor down as far as possible and then tilt the saw blade so the back end of the motor where the belt is housed is exposed and accessible as possible. Then remove the cover housing at the back end of the motor. This will expose the belt. Thenyou can remove the old belt and install the new one.
May 19, 2014 | Saws
I have a Delta 36-979 table saw. In a recent move, it seems I lost the drive belt when I took the motor off for ease of moving. Can I get a replacement at a local auto parts store or do I need to order...
I can't find any specs for this belt, You can buy it online from them the part number is 643928 and the cost is around 7.22, Sorry but this is the only information I can find for you.
Apr 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
I have a delta 36-600 table saw that the clutch or drive has quit working . the motor was rebuilt about a year ago now the drive slips is there a simple or easy fix or adjustment to the clutch for this...
If you have a motor with the no.1313314 and the motor runs ,but the blade spindel does not turn try removing the backcover plate . With this removed you might find that the toothed gear belt has broken. If this ,in fact, is the problem the belt is a Bando syncro,link 100xl.
Hope this rectifies your problem as I am waiting for a new belt myself.
E
Oct 10, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Looking for a manual for a Rockwell Model 8 motorized table saw. No. 31-205 type 1
Exploded parts diagram is here.
They don't have the operator's instruction manual online, unfortunately.
If you need an operator's manual, the Delta 34-410 is a 10" contractors saw that's reasonably close. Please bear in mind that this is more for table saw safety and operations than specifics of setup. The 34-410 operators manual is here.
If this answer helped, please vote for it. Thanks!
May 25, 2010 | Saws
The motor on my delta 10" table saw starts a low rpm and does not go into high rpm - after a a few seconds it fails the circuit breaker, and without the belt conected this does not happen. Is the motor...
This saw tends to have a problem where the belt rides "outside" the V-grove. Check that the belt is actually installed into the V-grove, and that the grove is in line. Mine was installed (at the factory) with the shiv back to front, so the belt would catch, and kick out. Maybe the same issue.
Jan 30, 2010 | Delta 36-716B 10" 1-3/4 HP 120/240V...
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
Saws Logo
65 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
