Question about Panasonic NN-SN657SMicrowave Oven
Door release button on panasonic the genius 1300w microwave sticks
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Genius 800w locked
On many models, you press "Stop / Reset" three times.
A hard reset may help: Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can probably download it (or one that's very close) here:
http://panasonic.co.uk/customer-Support/download-centre.asp
If that doesn't work, you can contact Panasonic UK at http://panasonic.co.uk/customer-Support/svc-dealer-locator.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-T687 (The Genius) door
You will need to remove the oven from the frame, then remove the outer cover from the door.
Once the outer cover's off, you'll be able to see that door opening button presses against the door opening lever, which presses up on the door key/hook to open the door.
Usually the problem is a broken door opening lever.
You can order that part directly from Panasonic here.
Once it's fixed, if you want to download the owner's manual, it's here.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic microwave touchpad not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may instead have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs, which depends on the exact model, one of these:
NNS688BA NNS688BAS NNS688LA NNS688LAS NNS688WA NNS688WAS
Please feel free to contact me directly if you need more help.
Posted on Oct 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Genius Sensor 1300W
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Aug 30, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
I have a Panasonic Dimension4 Microwave/Convection (the genius) and the push button door opener malfunctioned I think the bolt in behind fell off and it is disconnected and is it fixable thank you
Unfortunatley Panasonic has discontinued a lot of those parts. All of those pieces are plastic. I have actually repaired a few of those release buttons and levers by modifying them and puttng a bolt where the plastic tab or nub sticks out. Basically it is a pivot point and it has to be in the right spot and supported. One hint, I have NEVER had success with any kind of super glue or plastic cement on that kind of plastic they use in there. Thats why I modify it and bolt in something to make it last. Fabricated to fit. Not easy. It is a shame they dont still have parts for them they were such great machines. Sometimes the tabs on the ends broke off or sometimes it is the end of the lever that breaks. Have to unplug and take off outer cover and go look behind the front panel at the door parts. Good Luck!!
Oct 01, 2017 | Panasonic Microwave Ovens
Microwave genius sensor 1300w
I don't believe it is possible to change the display angle/tilt on this microwave. The unit ships with a protective film over the display that should be removed to make the display easier to read. However, this model is known to be difficult to read unless looking at straight-on. That and needing a flashlight to look at your food with the door open since the internal light does not stay on when door is opened. Good luck!.
Jun 13, 2014 | Panasonic NN-SN657SMicrowave Oven
My Panasonic 1300w microwave will not turn off. It doesn't cook but won't turn off without actually unplugging it or opening the door and leaving it open. Any help?
You may have a shorted door switch or a shorted relay on the control board.
You can see a help file on door switches here.
Dec 01, 2012 | Panasonic NN-SN657SMicrowave Oven
Over the range microwave oven
The problem is the release spring is broken or the button is sticking, pick up a small can of electronic cleaner attach straw and spray into the button crevis to break down the crud, grime, and dirt this should help release the mechanism.
Apr 23, 2012 | Panasonic NNH965BF Microwave Oven
Where can I find manual for Genius Sensor 1300w
http://service.us.panasonic.com/OPERMANPDF/NNSN657S.PDF
Feb 07, 2011 | Panasonic NN-SN657SMicrowave Oven
Shuts off after 15 seconds
sounds as if the magnetron has gone bad.this part of the machine is still under a warranty,and you need to call for a service technician to look at it.
do not use the unit until you get someone to look at it and or replace it.
Jan 31, 2010 | Panasonic NN-SN657SMicrowave Oven
Panasonic genius 1300w starts and stops
model # PeB2060smiss- not working at all. What would think is the problem?
Nov 09, 2009 | Panasonic Microwave Ovens
Gives me a small grunting noise than stops and seems ready to cook. Its a 9 year old 1300w genius and has been problem free till today. Thanks, rr
well i never a 9 year old microwave,,, time it found its way up to the dump yard then, by now you must have had your money's worth out of it, is it realy worth paying out to try to get it fixed up??? dont be silly, buy a new one, and have a nice flashy one for half the price
Oct 20, 2009 | Panasonic NN-T990SA Microwave Oven
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
Panasonic NN-SN657SMicrowave Oven Logo
47 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
