Omega altise tower fan is making a strange tinny sound
I turn it on and within minutes it makes an annoying sound, if I tilt it goes away.
  • 11 Answers
SOURCE: Computer making strange noise
This is not a problem most people experience this. Its just your fan making noise monstly because it is touching some wire inside. You don't need to worry about this.
Posted on Nov 07, 2007
gotgeek2
  • 565 Answers
SOURCE: MY IQON TOWER DRIVE IS MAKING A LOUD NOISE LIKE FAN WORKING OVE
Probably just needs replaced. Sometimes one can clean it and it will last a little longer. It's an easy job to replace it. Just download the manual for your model from the maufacturer's website to see how to gain access to the inside of the computer. Replacement fans are available at places like CompUSA or similar stores, or you can order one on the internet. Just take the existing fan out of the case and take it to the store with you to be sure you get the right one. Take care about static electricity, as it can zap your components, especially the motherboard and the memory sticks. Touch the computer case before touching any parts inside the computer.
If you don't feel comfortable changing the fan out, a computer repair place can probably do it for not much.
Posted on Feb 03, 2009
jubag14
  • 89 Answers
SOURCE: tower making loud fan noises
yes that is because the fan inside of your computer has a bit of dust on it there is not much you can do appart from blowing into the fan then that might help but not much else you can do about that sorry.
please rate my help to you.
thank you.
Posted on Apr 21, 2009
leecom72
  • 4806 Answers
SOURCE: I have fan failure. It has been making a strange
You need to replace the CPU fan as it has failed, I recommend that you refrain from using the computer until you have replaced the fan, this is because it has no way of cooling down and you will be running the risk of blowing the processor and/or the motherboard up.
The CPU fan is located inside the case and is attached to the motherboard on top of the processor.
Regards.
Posted on Jul 10, 2009
jhoeldorz
  • 169 Answers
SOURCE: How do I clean the fan on my computer
Try this easy to follow instructional video on how to clean your CPU fans.
http://reviews.cnet.com/4520-11319_7-6240575-5.html
Posted on Nov 16, 2009
Electric fireplace
Is it that soud stay for long time, let say 10 minutes?
It can be some piece of metal moving when fireplace heats up.
If this fireplace has fan installed, small lousy bit of metal can play.
Nov 13, 2013 | Heating & Cooling
My altise OMEGA 45W TOWER FAN cannot power up
That sounds like a bad PSU. Open the machine and clean if needed.
Jan 08, 2013 | Computers & Internet
I have a whirlpool quiet miser, ACE082XSO that is cooling fine, but makes quite a lot of tinnie rattling noise when I listen to it run on the outside of our bedroom. is there a fix for this noise problem...
Normally a sound like this is vibration or the fan making contact with the casing. If you pick up on the unit a press on it in different places and the sound goes away it i vibration. If its the fan there will be evidence on the edges of the fan blade. You can also turn off the power and slowly turn the fan and see if it hits. Just remember sometimes just moving the unit around will make a nois start or stop. good luck
Aug 09, 2010 | Whirlpool Heating & Cooling
I have the Aloha Breeze tower fan and it got knocked over by my dog while it was running. Now it will run for a while just fine when you turn it on, but after a while it starts making an annoying rattling...
Sounds like when it was knocked over, the bearing sleeve was kicked out of alignment. Since there is expansion to the sleeve due to heat (friction by the rotation), this only happens when it is running a while. When taking it apart, take a good look at both bearings to see if any damage has occurred, squirt a little oil into the sleeves and try it out again.
Jun 06, 2010 | Tower Aloha Breeze Fan
My Jenn Air French Door Professional Refrigerator makes a strange annoying knocking sound. It seems to come and go and happens for a few seconds to close to 1 minute. It will stop soon after I open the...
You have two fans and a compressor which could be making the noise. Inside the freezer behind the back cover is the evaporator fan. It probably stops running when you open the door. Hold the door switch down to keep the fan running to see if it's making the noise.
the compressor and other fan is under the unit accessed from the back behind the cardboard cover.
Nov 30, 2009 | Jenn-Air JFC2089HE French Door...
Strange straining sound
Either compressor is going bad or the fan is rubbing. There is a condensor fan that comes on only when the compressor starts. So check the fan out first to make sure that it is not rubbing or moving around. If that is not then check the compressor by letting it run for about 5 minutes then touch the top of the compressor. BE careful as it can be extremly hot that will show you one of two things either bad compressor or condensor is dirty and a garden hose with a jet blast of water will solve the problem. If that doesnt work either compressor is bad and will either need to be replaced for about 250 dollars or unit will need to be replaced
May 30, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Washing machine
sounds like you have something stuck in your pump. I know it sounds strange that it more than likly does not make any noise in the drain. But i garrenty you there is a problem within your pump. Tilt the unit back and prop against the wall. DO NOT TIP ALL THE WAY OVER! you will see the pump it has 2 clips unclip them take the 2 hoses off and remove the pump. water will come out so be prepaired with towels. look inside the pump there will either be money in there or a bra wire. MAKE SURE YOU TURN THE POWER OFF FIRST. Let me know how it goes
Jan 03, 2009 | Kenmore 22622 Top Load Washer
HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Apr 01, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Acer 6800
hi first of all check that nothing is touching the blades then spry some oil in the hinge (WD40..) make sure both ways of the fan are open for good air flow if the SUDDEN accelerations annoys you then connect it soo it will run all the time - take the red and black wires to the red and black wires of the 5v hardiscs good luck
Apr 20, 2006 | Acer CASE Mid-Tower ATX P4 350W FAN DUCT...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
