Question about Emerson MW8625W Microwave Oven
Manual mw8625w Need manual
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
John cunningham: that is brilliant! thank you.
Thank you so much, it is nice to bring joy to people and I consider that my reward.
Mar 21, 2012 | Emerson MW8625W Microwave Oven
What is the highest power setting? choices are low, defrost, medium, roast and reheat. no high???
Most microwaves run high at default, if roast and reheat are given that is your high setting, take one cup of water and run for 1 minute in each setting, the water that is the hottest is the high setting.
Mar 19, 2012 | Emerson MW8625W Microwave Oven
It just stopped working. It will not turn on. Is there something I can do to check what the problem is
even if you did find the prob. you would be hard press to find parts. counter top micro's are use them till they break and toss them.
Jan 10, 2011 | Emerson MW8625W Microwave Oven
Does not start. The power cord, plug, etc., are O.K.
Hello :
Maybe there's a problem with the power transformer or the power PCB [ Printed circuit board ] . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 29, 2010 | Emerson MW8625W Microwave Oven
I need manual for craftsman welder
You can get a parts manual at :
www.searspartsdirect.com
I just checked it and it looks like most of teh parts for it are obsolete. They do not offer an owner's manual. I checked for both since you did not specify which "manual" you need
Sep 29, 2009 | Microwave Ovens
Little plastic ring with wheels broke in several places
the purpose of the turntable is to more evenly cook the food. it shouldnt effect the mics ability to cook, just might take a little longer to thoroughly cook food
Apr 21, 2009 | Emerson MW8625W Microwave Oven
Need users manual
I need a user manual & parts list for a Quasar microwave, Model # MQ9968W built in 1991. Is this manual available in a pdf format or in hardcopy?
Nov 26, 2008 | Goldstar MA-1112 Microwave Oven
How to use the automatic defrost
You can download GE owner's manuals and installation instructions here.
Nov 20, 2008 | Emerson MW8625W Microwave Oven
What amp of fuse do I need
There should be a paper tag near the fuse holder, or the fuse holder itself should be marked as to current requirement.
Most older or smaller models used 15A or sometimes 12A ceramic fuses.
Newer or more powerful models use 15A or 20A ceramic fuses.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | Emerson MW8625W Microwave Oven
Emerson MW8625W Microwave Oven Logo
93 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
