Hoover oph716df stuck on cycle and wont finish the cycle, how do i reset it?
The machine is stuck on a cycle, with 1 hour 57 minutes and i have tried resetting it but have not had any luck! i have tried turning it off at the mains, holding down the start button for a minute but nothing works!! please help as i have a washing pile the size of mount everest!!
  • 67 Answers
SOURCE: paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
Posted on Mar 20, 2007
  • 1462 Answers
SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Posted on Apr 01, 2007
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
SOURCE: Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Posted on May 09, 2010
Whirlpool washer setting comes up with an 8 hour cycle, it used to be 47 minutes!
Hello Kim, we're sorry to hear about your Washer. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Washer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 12, 2017 | Whirlpool Washing Machines
My GE washer is stuck on a Stain cycle and it will not start. I can change the cycle, but it will not start and if I turn power off and on again, it goes back to Stain cycle. We've held the start/pause...
the G.E IS USUALLY RESET BY UNPLIGGING THE MACHINE A COUPLE MINUTES THEN PLUG IT BACK AND TURN THE ON KNOB TO ON THEN PULL OUT . THEN OPEN AND CLOSE THE LID SLIGHTLY) NOT ALL THE WAY JUST SLIGHTLY ) 6 TIMES WITHIN A 12 SECOND PERIOD , THIS SHOULD RESET THE WASHER IF IT DOESNT WORK THEN TRY THE SAME WITH THE KNOB ON THE OFF POSITION PUSHED IN
Feb 20, 2015 | GE Washing Machines
How do I stop my Hotpoint washing machine WMF740 which has been going for 7hours and is stuck on 1 minute
Is there a way to manually advance the cycle or is it all digital control panel? Do you see a reset button anywhere? Check the link I'm sending you on the manual.
Hotpoint Washing Machine Instructions For Use ManualsOnline com
Nov 24, 2014 | Hotpoint Washing Machines
My washing machine started as usual, but after going to empty the machine it seems to be stuck in the spin cycle. Any ideas? Can the machine be reset?
Have you tried unplugging the power and leaving it unplugged for a few minutes to try and reset itself? If that doesn't help then please provide the model number - should be located on the door somewhere.
Sep 16, 2014 | Maytag Washing Machines
Hitachi sf-6500px error
Possible error on the program due to a memory issue. After resetting, if the machine has the same fault with all the selected programs, then it is possible that the motherboard is faulty. Please check the INLET flow to be good and the drain pump to be clear.
Jun 25, 2013 | Washing Machines
My Maytag Neptune TL will not switch cycles, when I started the wash cycle it said 57 minuntes came back 1/2 hour later and it still said 57 minutes tried unpluging it to see if it might clear any erriors...
What happens if you do a Spin Only cycle with that wash load?
Does it fail to go thru the 12 min Spin Only Cycle?
Any error code to the console?
Do you want to troubleshoot?
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
Paused. now stuck. cannot open, turn off, etc.
Mar 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
