Question about Car Audio & Video
I need to add and auxillary input to my 2003 chevrolet silverardo bose radio. how can i wire one in?
  • 15,935 Answers
THE GM12-AUXV2 by P.I.E. will work for you.
It plugs into the factory radio changer port.
With this device installed, you will have created an auxiliary audio input to your factory radio, which will allow you to plug in any external audio source, like a portable MP3 player, satellite tuner, DVD player, or iPod, and play the audio from that external audio device directly through your factory radio. This is a direct connect device and NOT an FM Modulator. An FM modulator requires you to tune to an FM radio station in order to listen to the audio from the external audio device. While this is a direct connect interface, it is only an audio connection and does not allow you to control the external audio device that is connected to it.
Posted on Jan 19, 2009
Can i use my Bose for playing iheart radio or pandora or is it not capable of adaptation or blue tooth
Bose wave is not BlueTooth unless you buy the optional adapter, but you can connect other device via the auxillary input. You should get Heart Radio on FM.
Take a look at this video.
Bose Wave Music System 3 Review
Dec 02, 2015 | Computers & Internet
I am trying to connect my Bose Wave Radio to my Yamaha RX S 70 receiver so that I can listen to the radio through my speakers. Right now the speakers are connected to the Yamaha...but radio isn't playing...
There's actually 2 ways of doing this.
Using the variable out connections on the Bose, connect your L&R channels to the desired input, I recommend the auxillary, on your Yamaha and select that input. Turn the volume all the way down on your Yamaha. Turn the volume on your Bose all the way up; then readjust the volume as desired on your Yamaha.
Optional connection; the headphone jack. Connect a 3.5mm mini to stereo plug cable from the Bose to Yamaha in the manner described as above and use the volume control approximately the same way.
Dec 12, 2014 | Yamaha Audio Players & Recorders
How do i replace the battery on a 2003 Passat
Be sure to use an auxillary input voltage device (memory savor) so you do not lose ECM TCM and radio programming. Most cars have a seperate battery for this, but VW does not. It plugs into the cigarette light and supplies a small amout of power to vital systems. I picked one up at harbor frieght for $5.
Also, make sure the car is OFF. Disconnect the negative cable before the posative, and install after the posative cable.
Always match the AMP ratings or go higher, because of cable resistance building up over time and wear to the starter. Replacing the cables and starter would fix this issue, but add much cost.
Good Luck.
Mar 03, 2010 | 2003 Volkswagen Passat
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
Aug 24, 2009 | Bose Wave Radio
Auxiliary audio input for 2008 Mazda MX-5 with Bose sound system
Yes you can add auxiliary or ipod interface also xm radio
go here for more information
http://www.oemautosound.com/c-161-mazda-products.aspx
Jun 30, 2009 | 2008 Mazda Mx 5 Miata
Unable to connect ipod
Reset the radio (it has a processor) by just unplugging the power cord for about 30+ seconds and plugging it back in. If this doesn't solve the problem, try replacing the remote battery (CR2032- can be found almost everywhere batteries are sold) If all else fails, call Bose tech support. The cable you connected has nothing to do with this.
May 09, 2009 | Bose Wave Radio II
I connected my Pioneer GEX-XMP3 player through the auxillary terminals on my Bose Wave radio and the sound is very low. I connected it as stated in the satelite radio book. Help!!
Hi have you set the vlume of the MP3 player to its maximum? You need to do so since the AUX input behind the unit does accept fix line input as standard.
Glad to be of service...
Mar 29, 2009 | Bose Wave Radio
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
Connecting ipod to bose system
Look at the back of your 3-2-1 to see if the auxillary is a single or dual output. You will need that information when you go to Radio Shack, or you can also get at the Apple store, a connector from Gigaware that connects to the ipod. It was only $15-$20,
Jan 04, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
No sound from my TV!! HELP!!
assume its a bose system 12 (non digital or digital ?)
if you clarify the model of both tv and bose system i will tell you precisely how to connect tv to bose system,
but i must assume first that your cable box is connected to your tv via a scart cable , you must remove sound function from the cable and plug directly into cd5 unit on either auxillary or video input , then turn cd5 unit to that channel to play sound and use bose reomte to control volume (ok)
i would doubt thatthe TV has a audio output, many dont.... also it may be necessary to buy a scart to RCA cable at your local electronics shop or supermarket to completet he task at hand.
if however you are digital.....
make sure you are connectiong bose digital input to a digital (dolby 5.1 compatible) sound source.
sorry if you think i have over simplified the problem !
respect
Dec 02, 2007 | Bose Lifestyle 12 System
Car Audio & Video Logo
393 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
