Clean waste toner container xerox workcentre 7120
Keeter
  • 41 Answers
SOURCE: Waste Toner Full/ Not Install
Behind the little container for the waste toner there is a sensor that senses whether the toner basket is full or not. If the sensor itself is dirty, it can give a false reading. First try cleaning out the area under the container to see if the switch works. Also make sure the container is clean, because the sensor works by sight, so if it looks full because it's dirty, it will give a false reading. I have heard of people disabling that sensor in various ways, but that can get dangerous to the printer. I can't recall the details on that exact model, but I believe there is a diagnostic of some sort that can test that sensor to make sure it works right to begin with.
Posted on Sep 20, 2006
Soulvisitor
  • 1113 Answers
SOURCE: Waste Toner
 Remove the left rear side cover waste bottle is in the left rear corner of machine ..make sure to clean the neck of the bottle really good it uses sensor to know when full, if toner deposits stay on neck of bottle it cant see threw it so still thinks it is full, Toner is messy stuff, empty with care, while you are there locate the sensor that looks threw the neck and clean that too. You just saved 100bucks!!
Posted on Oct 31, 2007
  • 47 Answers
SOURCE: Replacing waste toner container
it is behind a panel in the lower left corner of the left side panel. Just pull the panel off (1 screw I think, maybe 2)pull out the bottle and carefully dump it into a plastic bag. Make sure you clean inside the neck of the bottle with a towel or rag otherwise the sensor will still think it is full.
Posted on Jun 12, 2008
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
  • 6 Answers
SOURCE: Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
Posted on Jun 02, 2009
Xerox 7120 error code 093-320 reset
bonjour j'ai un code erreur sur ma xerox workcenter 7125 je trouve pas de solution si qlq px m'aide merci d'avance code 093-320
Feb 05, 2014 | Xerox DocuColor 240 All-In-One Laser...
Xerox 7120 waste toner error ...
The trick about cleaning out the waste toner container is you have to also swab out the clear plastic piece the optical sensor reads so the device knows the waste toner is full. Clean that out and you should be able to get more than a weeks usage out of the waste toner container.
Hope this helps.
Aug 23, 2017 | Xerox Office Equipment & Supplies
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
How do I empty the waste on a xerox 7120
Better off replacing it, if you google it , the price normally is $20 or less. But you can take it out and empty it into a garbage bag, but there is a clear plastic window that must be cleaned to allow it to reset. They are pretty cheap. Google The Parts Drop. Most likely they have them.
May 26, 2011 | Xerox WorkCentre M-24 Color Copier
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
Can i empty the 7120 waste toner bottle?
No you should not empty this bottle. It is designed to keep the excess toner inside itself and should be disposed of properly. NOTE: To return the used Waste Toner Container for recycling, follow the instructions included with the new container. If the instructions or shipping label are not available, click on the [Recycling] link under the Product Resources section of this window for additional information. Follow this link for detailed instructions on how to replace the bottle once you have a new one onsite. http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=161,E=0000000002703235792,K=5302,Sxi=14,Case=obj(1554) Hope it helps!
Feb 10, 2011 | Xerox Office Equipment & Supplies
Xerox work centre 7120 message say change waster toner, I found where it is but how do I change it
You can either dump out the waste toner into a garbage bag, or replace the whole toner collector. If you decide to dump it out yourself, you need to make sure that the container is extremely clean prior to reinstalling it into your copier, as sensors on the copier end detect the level of used toner by optic sensor.
-David.
Nov 03, 2010 | Xerox WorkCentre M-24 Color Copier
147 people viewed this question
jasbo
jasbo
