Question about Sanyo Televison & Video
Sanyo flat screen tv half of screen upside down
Half screen upside down
  • 208 Answers
SOURCE: Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Posted on Feb 03, 2008
SOURCE: sanyo lcd tv flat
I have researched this problem and it is so common we that own this piece of junk ought to form a class action suit and sue. It is caused by a bad part or bad connections to a part called a backlight inverter. It seems the LCD needs a higher voltage than supplied by the 12vdc power pack so this part re-chops the DC voltage to generate the LCD requirement.
The date of manufacture is on the back of these TVs and all the problems seem to be from those made in 2006 to 2008
Posted on May 05, 2009
  • 6 Answers
SOURCE: my sanyo plasma flat screen tv will not come on....
For what it's worth, you can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had some issues with this TV last year. The solution almost always seems to be to replace the Power Board and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop):
1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
Posted on Aug 07, 2010
AJIN G
  • 6694 Answers
SOURCE: I replaced a new motherboard
hi,
do on thing revere the polarity of vertical yoke connection. just see the picture bellow for verical connections. inter change the wire of vertical coil.
Posted on Jan 19, 2011
SD Tech
  • 14553 Answers
SOURCE: scratch on sanyo flat screen tv
The overlay or outer screen on any LCD or Plasma is bonded to and cannot be removed/replaced short of replacing the entire Panel or display unit which needless to say costs more than the set did when new.
If its an older projection set the outer clear screen may be available depending on brand and model number.
Posted on Apr 18, 2012
I have a Sanyo 55 inch flat screen TV, and half of the screen is darker than the other. What is the problem?
The T- con board has two flat ribbon cables. Make sure they are both seated completely at both ends. If all looks well then replace the board. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 08, 2017 | Sanyo Televison & Video
The right 3d of my 42" Sanyo is dark for about an hour and than splits with half upside-down until warmed up after you turn it on. It seems to be getting worse.
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 27, 2015 | Sanyo Televison & Video
I purchased a Sony 46 inch TV 2 years ago. I recently experienced a condition where the top half of the screen has horizontal lines through the signal. The bottom half of the screen looks perfect. Also...
the screen driver can make this fault it sit at the back of the screen. if you change that it should work fine after beening replaced. they can over heat.
Sep 22, 2013 | Sony KDL Televison & Video
Change tv screen size
Refer the user manual to your TV for details about changing the aspect ratio of picture.
Jul 10, 2013 | Sanyo Televison & Video
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
Sub picture of my sanyo lcd-32k30 in pip/pop are not clear
my sanyo lcd 32k30 have a problem when i turn on half on the screen the picture is ok and the half is black after a few seconds the picture is full what is the problem? can you help me of this trouble of my sanyo lcd 32k30 thank you
Jul 19, 2011 | Sanyo DP19649 LCD TV
I have 1 37" Sanyo LCD TV. The screen is split
bad screen driver boards, it can sometimes be corrected by tapping it on the side that is affected NOT ON THE SCREEN I MEAN ON THE TOP. The only way to cure the problem is replacing the panel.
Nov 14, 2010 | Sanyo DP37647 37 in. LCD TV
Televison & Video Logo
63 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
