I need parts for my superser mobile gas heater
I need the brass thing that gas pass through it. I penetrated the net inside the cylinder (brass) so I need another one to replace.
3 Suggested Answers
  • 4736 Answers
SOURCE: internal 1/2 psi propane regulator is not passing
What's the pressure to the heater? It should be a minimum of 11 to 13 water column inches. Also, make sure that your heater is in fact a propane fueled heater. Don't go by whats on the box it came in. Look at the manufacturer's tag(s) on the heater. It may be a Natural Gas unit instead of Propane unit. I've seen this happen before. In which case it won't work and can not be converted.
Posted on Feb 02, 2011
  • 2597 Answers
SOURCE: helius superser calor gas heater
Blocked pilot could need cleaning, spark electrode could need cleaning or out of postion .
Posted on Mar 03, 2012
Hi, could anybody tell me if it's normal to smell the gas when the heater is on?
Sorry but if you value your life then pay a professional to test it and repair if needed .
Dec 10, 2016 | Heating & Cooling
Delonghi Superser won't light there is gas getting
Clean pilot first see if it lights if not you could change thermocouple
Apr 03, 2012 | DeLonghi Heating & Cooling
Helius superser calor gas heater will not light
Mar 02, 2012 | Heating & Cooling
I have a superser F150 mobile gas fire, it sparks but wont light, am i missing something ?
the pilot light is blocked blow it out with an airline or try using a hoover
Nov 04, 2010 | Heating & Cooling
My Porter Cable FN250A only shoots nails sporadically. When I lift up the nose piece, it appears that the "hammer" is not fully retracting.
Piston not retracting is caused by several issues. Bent or broken driver, worn piston oring or loose or broken check seal. Remove head and examine driver for bent or broken, adjust as needed. Check that piston oring fits snug, piston should not drop down cylinder under its own weight. Pull cylinder from body and check that black band (check seal) is in place around holes in cylinder. Good luck
Oct 26, 2010 | Porter Cable Tools & Hardware - Others
Rheem Power Vent gas water heater (only 2 years old) had electronic thermostat/gas valve fail. Received warranty replacement today but I can't get the old assembly out. I cannot get it to budge even...
Hello Try a "breaker bar" on the end of the pipe wrench.Good news is that the control threads are BRASS and the tank is steel,meaning the control will always come out (without spray oil).Counter clockwise is correct.Have faith and lay into it!
Sep 18, 2010 | Heating & Cooling
COMES ON ONCE OR TWICE BRIEFLY BEFORE FINALLY STAYING ON ?FURNACE BLINKS A CODE 13
The first thing I would try is clean out the manifold inside furnace where the gas passes through. If that doesn't work it sounds like your flame sensor needs to be replaced or at least cleaned.
Dec 24, 2009 | Dayton Gas Furnace Heater
How can I connect a 20# tank?
lp gas hose, regulator, pipe fittings to adapt the hose to your heater.. use brass fittings.
Mar 08, 2008 | Procom 10K BTU, Vent Free, 2 Plaque...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
