Question about Bosch Washing Machines
Bosch WFL 2450 has started to leak during spin cycle (only). The unit is dead level.
The leak appears to come from the front right corner. It's not a great deal - say, 200ml.
  • 4 Answers
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Posted on Sep 05, 2008
  • 223 Answers
SOURCE: Bosch nexxt washer is leaking from underneath
All the things that greendude said plus check the seams inside the drum as if these have even slightly parted it could cause the leak you're describing. Good luck.
Posted on Sep 26, 2008
barkencoa
  • 3463 Answers
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
  • 106 Answers
SOURCE: Bosch WFL 1660 Front end
After disconnecting the mains open up behind, it could be a shock absorber (damper) which is broken.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Posted on Feb 28, 2009
  • 163 Answers
SOURCE: Bosch WFL 1300. The machine does not finish the
pump could be clogged or bad,or door switch is bad.any codes?
Posted on Mar 06, 2009
How to remove *** wire from bosch wfl 2450?
Here you go....
http://www.scribd.com/doc/187416757/Bosch-Maxx-Wfl-2450
Aug 21, 2014 | Bosch Washing Machines
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Bosch WFL 2462 is out of balance during spin cycle
I would think it unlikely that the springs have failed unless they are fractured.It's more likely to be the shock absorber or absorbers. Depress the drum and watch how it settles, if it continues to 'bounce' around its the absorber(s), if it settles after one bounce then it's something else.
Make sure it's levelled ok
regards
w
Nov 02, 2011 | Bosch Classixx WFL 2462 Front Load Washer
Bosch WFL 2872 washing machine that is leaking during wash/rinse cycle. Looks like it is due to rubber manifold between drum and pump - how difficult a repair is this?
Bosch WFL 2872 washing machine that is leaking This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
or it could be the seal
Oct 09, 2011 | Bosch Axxis WFL 2060 Front Load Washer
What is the life expectancy of Bosch front loader (under counter)? Making loud noises during wash - not spin - cycles. Worth repairing?
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Dec 27, 2010 | Bosch WFK 2401
Frigidaire front loader walking during spin cycle
Have you made sure that all the shipping bolts and stuff were removed? this happened with our Bosch and we found out we had kept three bolts installed that needed to be removed
Jan 12, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer leaking
First of all check the outer lip of the doorseal. It must be damage freein the lower half of the door opening. Then lift the folded part of the lip which faces towards the drum. Examine the doorseal with a torch. If any holes are evident the doorseal must be replaced. If you are in melbourne metro area you can call me on 0417362396.
Regards Sam
Jun 16, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfl 2450
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
