Question about Kitchen Ranges
D Shape Knob required for Necht Gas Oven Model number AME10001
D Shape 17mm shaft which terminates in the know
  • 1122 Answers
SOURCE: require new oven grill knob
go to sears.com,click on parts,put in your model number and see if they have the part you need-mike
Posted on Nov 11, 2008
alandc
  • 25 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
  • 77 Answers
SOURCE: magic chef self ignitor top,, how do u get the
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Posted on Aug 12, 2010
justinbur167
  • 257 Answers
SOURCE: An Ilve JC80 LM with
Hello nickypaige,
The only place you can get parts is at the following web-page and you have to go threw there department. You will need a new oven control. Follow this link to get your parts http://ilveappliances.com/part.php
Thank you for choosing FixYa.com
Justin
Posted on Apr 05, 2011
SOURCE: I have a magic chef gas stove model #3167VUV and need to replace the oven knob as you cannot see the temp. numbers anymore where to get part in white
Try www.appliancepartspros.com if it is still available.
Posted on Nov 19, 2012
Necht gas oven
May need to adjust air Venturi too much air
Mar 27, 2014 | Ovens
I don't know which part to order?
Will need model number to follow up.
Or send photo to supplier.
It is also helpful to know the shape of the shaft, eg. D-shape.
Jul 23, 2013 | KitchenAid KGRA806PSS Gas Kitchen Range
I don't have the model number for this range but it's a very old magic chef gas oven. What I need is the oven temperature knob. The knob used to have all of the temperature numbers printed on it however...
If you go any hardware store (Lowe's, Home Depot) they have universal knob replacement kits. Take your old knob with you and ask for help from someone who looks like they know something (the old guy). Its so much cheaper this way, exact replacement knobs can run $20 or more each. Good luck!!
Jan 16, 2010 | Magic Chef 9122 Gas Single Oven
Old (30 yrs?) tappan gas range.loose oven knob
remove top of range, locate shaft from knob that is loose, there should be a nut where shaft goes into valve, tighten nut in small steps
Sep 17, 2009 | Tappan TGF320 Gas Kitchen Range
Necht model 720 built in electric oven. Fan
If the oven fan is working o/k, thenyou need to replace the fan oven element.
Please rate my solution.
Thanks.
Sep 16, 2009 | Ovens
Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Hotpoint Gas Range (model: RGB524PN1AD)
pull the knob off note the position of the brass gas valve turn the knob 90 degrees see if the position of the brass piece changed the same as knob if not inspect the knob see if its cracked also look on the shaft see if there is a small d shaped metal piece on it if there is it goes up inside the knob let me know what you find will advise from there
Jan 21, 2008 | Hotpoint RGB524 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
