The screen of my Hp 655 turns black Whenever I turn on the laptop, the screen never turns on, it just remains black and the power light will still remain on as well
2 Suggested Answers
LaptopExpert
  • 458 Answers
SOURCE: upon boot up, screen remains black,disk power up briefly
HOW TO FIX YOUR DV6000/DV9000/DV2000/tx1000/tx2000
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
Posted on Dec 04, 2009
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
My hp laptop screen goes black after being on for a few minutes
The problem could be the backlight or its inverter is bad. IF picture remains but lights only go out. Also it is normal for the screen to go black if the laptop is not used.
If the picture itself remains on the display but it just goes dim, try turning up the brightness, if noting happens, most likely the backlight of the screen or its inverter is or has gone bad.
Would need to be confirmed in person.
If the picture does not remain on the screen and the laptop shuts off, your charger might not be working, and your battery is low.
Would need to be inspected in person.
Jun 11, 2012 | HP Computers & Internet
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
My hp pavillion tx1320us is powering up but the screen remains black
try to turn off the laptop. Remove the cables and battery on the pc. Press and hold the power button for 8 secs. Then reinsert the cables and battery on the pc. Turn on the laptop and check if the screen still black. If it is, make sure that the monitor power light is on. Otherwise, there might be a problem on the video card. If you know how to reseat a video card, go for it and here is the step by step, instructions:
Turn off the laptop, remove the cables and battery, remove the screws at the bottom part 4 corner sides, remove the hard drive, remove the optical drive, then remove the video card and reinsert it. Then reinsert the other peripherals in descending order.
If still did not work, call HP and have your video card replaced...
Jul 27, 2010 | HP Computers & Internet
HP tx2000 - black screen.
Hi
The problem you are experiencing is related to the screen of your Hp.
All you need to do is to is to get to a computer store and get your screen replaced.
You can not fix a damaged screen.
GOOD LUCK
Jun 17, 2010 | HP Pavilion TX2000Z Notebook
The screen remains black when computer is turned
maybe a hardware problem, on booting the pc, move the screen to every angle to see if there is a connection problem.
If so, then use your warranty if you have one.
Jun 13, 2010 | HP Pavilion dv1000 Notebook
The screen turns black
hi,
Please tell me your laptop model and brand.(I guess and Hp dv200/6000/9000\0 If i am correct then you must replace your Mobo.\this is a heavy job if you dont have the experience or tools. \We can fix your mobo for around 89 usd.
10001 buckwood ave 79925 El Paso Tx.
Contac us if you are interested
Thanks, please leave feedback
Vcrtech
support@vcrtech
vcrtech@hotmail.com
www.vcrtech.com
Apr 29, 2009 | Computers & Internet
Compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
Blank screen. Remains blank
Power down, remove the battery, remove the power plug. Hold down the power button for at least 30 seconds. Remove and reinstall the memory module(s). Re install the power plug and try to power back up and see if it works. If it does, reinstall the battery ad you're done. If not, get back to me for some more ideas and further diagnosis.
Thanks and have a good day!
Ron
Dec 15, 2008 | HP Hewlett Packard Pavilion dv6355US PC...
Computers & Internet Logo
315 people viewed this question
David Payne
David Payne
