Question about Tomtom ONE GPS Receiver
Won't find a GPS signal
'The unit was working very well and all of a sudden it quit and won't find a gps signal. Everything else seems to still be working though.
  • 5 more comments
  • allenb34 Jan 19, 2009
    I tried the factory reset with no result. I had nothing to backup so didn't have anything to install. Thanks anyway.
  • fireman037 Jan 19, 2009
    my tom tom xl wont find a signal...i have no sat bars..its saying i must be inside a bldg..but im not..
  • Anonymous Jan 24, 2009
    I am having this same problem. My gps just states waiting fo a valid gps signal
  • andyp001 Jan 25, 2009
    i ave same problem tryed reset button but no different tom tom worked in morning after being in pocket for 6 hours switched on and wont find gps signal any ideas
  • tattanya Mar 06, 2009
    i have the same problem. stopped working can see everything just won't give me a signal. updated and everything. can someone help me?
Tomtom one was doing the same. Switched it on "no valid gps signal". Pushed a paper clip into the reset hole on the bottom. Tomtom restarted and all Ok.
No probs...
Posted on Mar 05, 2009
My tom tom one has lost signal while driving down the road how can i fix this
Posted on Jan 21, 2009
    Problem Solver:
  • 12 Answers
Try a factory reset on it. Or if you have been doing backups of the files on there reinstall those and see if it works again.
Posted on Jan 19, 2009
No longer receives GPS signal
Does this unit have an input for an external antenna? If you get/borrow another antenna you could see if it starts working. That might isolate the problem to the antenna.
Jan 23, 2010 | Lowrance iWAY 250C GPS Receiver
The GPS was working then then just out of the blue
THE GPS SATELLITE RECIEVER HAS FAILED, REPALCE THE UNIT OR HAVE IT REPAIRED
Oct 01, 2009 | GPS
Hello, There, Recently my Harman/Kardon GPS-300 quit working on Nevigation section (Music and Settings are fine), There are two symptoms: [1] Regardless of whether I'm in the house or in my car, after the...
The first bit of advice, never leave the gps in the car the temperature can warp the motherboard and the case
The battery is low too low to allow for the unit to reach the satellites. eratic behaviour is also part of low power. recharge the battery
Aug 12, 2009 | Harman Multimedia GPS300 Car GPS Receiver
Standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Jun 30, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
Omnitech Model 16878 GPS ''waiting for GPS signal''
There is a firmware update to correct this issue, if you are still having it.
Jun 20, 2009 | GPS
Nextar m3 and no signal
Hi.
You are facing this problem because of the US GPS Satellite because there's a sudden change with the code signal which leads to GPS signal anomalies.
Even though you've traded it. the problem is still there.
It's better to go with another brand or model.
As this problem cannot be fixed with this unit.
Jun 16, 2009 | Nextar Q4-04 Car GPS Receiver
KW-NX700, constant "lost gps signal" all of a sudden!
Hi,this problem exist because the navigation is bloqued, if reset the problem is the same.
The solution for this problem is:
desconect de battery car, and wait 15 minutes
conect the bactery, work`s fine
cumps
Luis Gabriel Portugal
Lutrónica
Dec 12, 2008 | JVC KW-NX7000 Car DVD Player
HP iPAQ Bluetooth GPS, IPAQ has no signal
I noticed now that the 'green lite' on my receiver does not come on at all. I can not find where I can get a replacement receiver
Sep 09, 2008 | HP iPAQ Bluetooth GPS Navigation
No GPS Signal in TomTom One XL all of a sudden
I suddenly lost the GPS signal today and could not get it back. All I got was the "No valid GPS signal". My solution was to tap on the GPS satellite bars when in the route map. this brought up the "Status summary page of the TOMTOM.
I then again tapped the satellite bar which brought up the "GPS Status" page. I then tapped the bar labeled "configure".
The radio button next to the option titled "Minutes (dm.m') was selected. I then moved the selection to "Degrees (d.d) and it started working.
I had just downloaded the GPS fix 5 days ago so it is not like this suddenly caused it to stop working.
This may not work for everyone but this is what it took to get mine working.
Cheers
Jul 09, 2008 | Tomtom One XL GPS Receiver
Navman icn510 gps reciever problem
How long are you waiting and are you moving while it is trying to acquire signal? These receivers are using older circuitry that may take up to 20 minutes to first acquire a signal from a cold start. If you are moving it may take longer!!! The good news is that after you have initially acquired a location, if you turn the unit off it will only take a minute or so to reacquire after it has "warmed" up.
Oct 22, 2007 | Navman ICN510 GPS Receiver
Tomtom ONE GPS Receiver Logo
380 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
