SOURCE: How to install D-link DIR 300 for MACBOOK
You shouldn't need to install anything off the CD. Simply plug your Macbook into the DIR-300 via ethernet (making sure you manually set your Macbook's IP to 192.168.0.x (where x is anything from 2-254). Then open up your web browser and type 192.168.0.1 into the address bar. This will log you into the DIR-300 (I think the default login is "admin" with no password).
Refer to the manual for the configuration for the rest of your setup.
SOURCE: Installation linksys wireless-g router
In order for you to setup the WRt54G to work with your Ibook you nee d to manually configure it since the setup CD for the WRt54G wont run on your MAC computer, In manually configuring the router you need to access the setup page of it and there you can set it up, I will advice you to contact Linksys tech support so one of their tech can walk you through with the process the number 800-3267114 they are open 24/7...
Hope that helps...........
SOURCE: how to install a wireless router without cd
You can download the device drivers from NetGears own website @ http://kbserver.netgear.com/products/WGT624.asp you will need to select the EXACT model( version you have - this can be found on the stamp underneath the router that has all those barcodes on) and download the latest drivers for yours. by doing this it will trigger 1 of 2 responses:
1. You have the latest version, no update is needed
2. You must setup your device before updating drivers. to do this please select OK
1 - Will trigger an auto setup of the device.
2 - Will take you through the setup wizard itself
which depends on how your router was shipped. If you have brought the router 2nd hand then you can obtain a new setup disc free of charge via the same site if neither of the above work.
For future ref: PLEASE INCLUDE YOUR 'FULL' ROUTER INFO-Different models of the same router can work quite differently and you may not get a best fix without it
Best Regards
Cruton
SOURCE: LOST SOFTWARE TO PARKERVISION WR 1500 --- PLEASE HELP ! ! !
You can download the manuals at http://straylightsoftware.com/downloads/parker2.html
SOURCE: lost installation cd for belkin F5D7234-4 G
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
