Question about HP LaserJet Office Equipment & Supplies
How do I reset hp laserjet p2055dn to factory default
How do I reset hp laser jet 2055dn to factory default
Nikhil Gedam
  • 87 Answers
SOURCE: low memory display on HP Laser Jet 3050
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Posted on Nov 03, 2008
SOURCE: Free HP LaserJet 1300 Printer Driver
How can I find the free Printer Drivers for HP Laser Jet 1300 printer
Posted on Nov 09, 2008
  • 327 Answers
SOURCE: hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
Posted on Dec 15, 2008
SOURCE: hp laserjet p2055dn Replace fuser unit
That is a job by it self. If you don't want to damage your printer, I'd suggest you take it to an HP dealer pay some money and get it first checked and if so be the case that it has to change, let them change it.
Posted on Aug 18, 2009
SOURCE: Model - HP Laserjet P2055dn. Issue - 49 Err
I had the same problem. The source of this problem, the USB printer port is broken, then I use network configuretion. The poblem is solve.
Posted on Jun 02, 2010
HP laserjet p2055dn not gave print
Do you have Hp laser jet P2055dn installation disc with you ? if you don't download it through HP website .
The printer needs its software to comunicate with your PC.
Feb 13, 2018 | HP Office Equipment & Supplies
Smearing on HP laser jet 2055dn
That sounds like a drum issue. Try replacing the toner or have you done that already? Give me a call if you ever need to replace the toner. I can beat out Staples and Office Depot. Damien @ iPrint Technologies - 818.700.7419 Dir.
Aug 28, 2014 | Office Equipment & Supplies
Hp laserjet p2055dn
You may have a firewall that takes effect...such as anti Virus firewalls or windows firewall , ... off them you will have high speed.
Jun 24, 2013 | Office Equipment & Supplies
HP P2055DN LaserJet: I/O card not ready
Check your network connection. I got that message on my 2055dn. The problem turned out to be a defective ethernet switch where the printer cable hooked up to the network. A new switch fixed everything.
Oct 16, 2012 | HP P2055DN LaserJet Monochrome Printer
Hp Laser Jet P2055dn printing black line down the middle
The line in the middle of the page is caused by a damaged or worn fusing assembly in the printer. Here is a link to an article showing this issue on the Laserjet 2100 printer and how to replace the fuser unit. Your printer just needs to have the fuser replaced, it is part number RM1-6405 and is available from Amazon
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jul 19, 2012 | Ricoh Aficio CL3500N Laser Printer
HP LASER JET P2055dn 10.000 SUPPLY MEMORY ERROR
I have an HP LaserJet P2055dn and I am getting a 10.000 supply memory error. I've checked HP's website and I am not finding anything related to this problem for my printer. What do I need to do?
Thanks,
Mike
Jul 17, 2012 | HP P2055DN LaserJet Monochrome Printer
Reset to factory defaults settings in HP CP1525n printer
Min printer laserjet cp1525n color skriver lav hukommelse hvad hvordan t?mmer jeg den
Jan 12, 2012 | HP Laser Jet Pro CP1525N
I have hp printer laserjet p 2055dn I got this error on printer screen b0605 then I tried the solution from hp website ...
It is posible to have problems with your usb cable. Othert possibilities is that the printer usb port is broken
Mar 24, 2011 | HP P2055DN LaserJet Monochrome Printer
I have to install a hp p2055dn printer defining a IP address
go to menu button on the front panel of printer. then go to network setting . assigne there static ip with subnet mask and default gateway of you network.
Aug 22, 2009 | HP P2055DN LaserJet Monochrome Printer
How to reset an HP LaserJet 3055
If you go in your user manual to page 241, it shows the following instructions on how to reset the printer to factory defaults. One important note is that you will lose EVERY stored piece of information including phone numbers and such.
To restore the factory-set defaults
1.
On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Service, and then press .
3. Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
Hope this does it for you.
Jun 19, 2008 | HP LaserJet 3055 All-In-One Printer
8,073 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
