Question about Sony Handycam DCR-TRV18 Mini DV Digital Camcorder
Firewire port damaged
All of a sudden I cannot capture footage from my dcr-trv18 to my computer via firewire. I have tried using another firewire cable, I've checked the computer port connecting it to a hard drive, and tried connecting the camera to another computer, and reset the computer for possible errors. So, the firewire port from the camera is damaged. Is there anything you suggest I can do before taking the camera for repair? Thanks cecim
  • Cecilia Medina Jul 04, 2007
    I appreciate your response.
    I discovered later, that the firewire port from the computer was also damaged, I guess it happened during a thunder storm so I suppose it was burned or something. The computer is fine, I have installed a PCI card to solve the problem.
    But... I want you to know that I took the camcorder to my local Sony support service and they want to charge more than 700 US for changing the whole card, which is crazy since the camera cost me almost the same, only 4 or 5 years ago.
    So I guess these Sony products are expensive disposable devices, and we should be aware of it when we purchase them.
    Very disappointing!!!
    cecim
    Scholar:
  • 35 Answers
Take a magnifying glass to the firewire port on the camera. Check to see if it looks damaged at all. Sometimes the port has become disengaged from the internal component. Sometimes it's simply damaged because the cable was inserted improperly. They are not very rugged. In my opinion, you followed perfect troubleshooting techniques. Time to send it in for an estimate.
Posted on Jul 01, 2007
SOURCE:
I have the sony DCR-HC26E handy cam i'm trying to connect it with my pc (windows 7) by using usb cable it wont work my pc doesn't recognise my camera ....thanks
USB connection will allow still photos ONLY to be capture to a computer. To capture the footage from the tape you will have to connect with a firewire cable, also called iLink or IEEE1394a. Windows Movie Maker will be one program that can capture the footage.
May 19, 2011 | Sony DCR-HC26E PAL Mini DV Camcorder
How do you capture footage on a miniDV cassette from a Sony DCR VX-2100 Digital Handycam on to a PC?
If you have Windows Movie Maker installed, this would be very easy. Just connect the Camcorder via the FireWire supplied. Go to Windows Movie Maker and select CAPTURE from device
Feb 19, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
Hi All, I have DCR-TRV238E Digital 8 Handycam... I want to transfer the recorded video to my computer... Can you please tell me where i can download the software to upload the video on to my computer...
All of pre-HDD cam does have FireWire port somewhere in it (or at the docking station in case of SONY's)
In order to capture the footage from the cam to your PC,you need the Firewire card and the cable.Should be available at any computer hardware store.All you have to do is to install the card to your PC,connect your cam to your computer via the cable,then capture the video by your favorite video editing software.
Yes,that sounds a bit more difficult than drag-and-drop work in USB-connection camera,but not too difficult to understand,of course.
Aug 07, 2010 | Sony Handycam DCR-TRV260 Digital Camcorder
Need driver to transfer video to using Vista
to transfer video from your camcorder to your pc you will need a firewire cable (ieee 1394). only with this cable you will be able to transer video.
you will also need a firewire port on your pc.
if you don't have one then you can buy a firewire pci card.
see this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
Dec 30, 2009 | Sony Handycam DCR-TRV18 Mini DV Digital...
Your how can i load my footage to pc from sony DCR-HC52E via firewire
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!
Sep 26, 2009 | Sony DCR-HC52E Mini DV Camcorder
Can't Import Footage Via Firewire with Sony DCR-TRV900E and Vista
Hi nash
I ma having the same problem... Did you get a solution in the end?
Mar 16, 2009 | Sony Handycam DCR-TRV900E Mini DV Digital...
Capturing Footage with Camera
USB streaming does not work for Windows Vista. Use the firewire/ilink connection instead.
Roger
Feb 08, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Downloading video's to computer with the dcr-trv8 handycam
You should be able to hook up through usb or firewire. If your computer has a firewire port on it you can but a firewire cable that works with your camera and then use windows movie maker to capture the video footage. You can then burn it to a dvd.
Jan 21, 2008 | Sony Handycam DCR-TRV8 Mini DV Digital...
Video capture problems
Sounds to me that the bit rate on your PC or capturing device is not as high as that now available through the firewire ports. Try increasing the bit rate in your settings and see if that helps. Or have you always used firewire?
Aug 19, 2007 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sony Handycam DCR-TRV18 Mini DV Digital Camcorder Logo
222 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
