Question about KitchenAid 24 in. KUDP01DLBS Free-standing Dishwasher
Where can I buy the cable repair kit for my Kitchenaid dishwasher
The door spring on my Kitchenaid dishwasher model KUDS01FLSS5 broke and the door falls open. Where can I buy the parts to fix it? I can't seem to find it online. Thanks
OK, pretty easy fix. Look at diagram 10 here:
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
Door falls open
The cables that are connected to the springs are broke, atleast one anyway. You'll need your model number off the machine to get them from a parts dealer. once you have them, pull the machine out a little ways and they install on the left and right side lower area.
May 28, 2012 | KitchenAid Dishwashers
I have a Kitchen Aid dishwasher model # KUDSO2SFRSS. When I open the door it just falls to the floor. The spring has broke. Is that an easy repair, and can I buy the repair kit online?
Hello, welcome to FixYa.
Based on your description, I'd say you are correct ( yes you can get the parts on-line and I believe most homeowners aka do-it-yourselfers can repair this ). Either one or both of the door link kits/springs broken. It's an easy enough repair, though the unit does need to be pulled out, slightly
First, slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likely least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "" "" to name a couple.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part# 1159210 @ repairclinic.
I recommend replacing the entire kit and checking the spring itself, if it looks ok and not stretched or broke it is likely ok...they are seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today. Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
Macmarkus :)
Oct 27, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
I opened the door on my dishwasher heard a pop and now the door is heavier and droppes open?
One or both of the door springs came off or broke. If you take off the bottom panel you should be able to look with a flashlight and see.You can buy the springs and replace them.
Apr 06, 2011 | KitchenAid Dishwashers
My dishwasher door springs appear not to work and will not hold the door open. How do you replace or reattach the springs? Thanks, JoAnne
they actually arent springs, it is a cable and has probably broken or come apart. You can order this part through KitchenAid and replace yourself. Or call a repair rep.
Feb 10, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishwasher door just falls straight down.
There are some cables that connect the door to the springs, the most likely suspect is that one of the cables has broke, The link below has information on the parts needed to make the repair. Let me know if it is helpful.
May 11, 2010 | KitchenAid 24 in. KUDP01FL Built-in...
How do you repair or replace the door tension spring on a KUDP01FLBT2 built-in Kitchenaid dishwasher? Thanks
If your door falls down or is noisy I have put together some instructions here on how to repair. You will need a kit part number 8194001, it is relatively inexpensive, let me know if you have questions.
Door falling down or creaking
May 01, 2010 | KitchenAid 24 in. KUDP01FL Built-in...
Kitchenaid dishwasher KUDK02CRBS the spring on the door broke? Is this a easy fix, where do you access the spring
Turn off the power to the dishwasher.
Remove the access cover on the bottom front of the dishwasher.
Lying on the floor,you can see the door hinges and replace the spring.
Feb 12, 2010 | KitchenAid 24 in. KUDK02CRBS Stainless...
The springs in the door broke, How do you replace them?
Unfortunately you will have to disconnect the water feed line.
pull out dishwasher 6" to access the springs on each side of the unit
Feb 10, 2010 | KitchenAid 24 in. KUDS02SR Built-in...
38 year old kitchenaid KDI-16 imperial dishwasher
yep you can just get springs from lowes or home dept or your local hardware store; they're often in with the hardware (i.e., screws) and not plumbing. remember that the springs need to stretch out a bit, too; so you may end up buying springs that look shorter than they should, but they eventually habituate.
Jul 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDP01DLBS Free-standing Dishwasher Logo
1,823 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
