Question about Home
Now fix leaking heatstore shower
2 Suggested Answers
bloues
  • 56 Answers
SOURCE: Hello I have a Heatstore aqua plus shower Model
Hi
Im Rossouw
I would think if its a electrical mixer for ur shower with its own thermostat that that will be the couse . undo the cuver plate and the tap meganisem to get to the thermostart, put it on 0 and then 60 degres put everything back and c if it dident just jam. if dat dosent work the thermostat may be broken
plz rate my solusion if u have an electrick shower
Posted on Jul 12, 2010
How do I fix a dripping shower head in a stand-alone shower? We have already tried to replace the valve assembly but it still leaks.
Obviously this is a leak in the valve. They are no fun to work on. Some of the higher end models of valve have seats that you can change and along with the ball and other hardware, that should stop the leak. If not you will have to replace the whole valve assembly.
Dec 16, 2015 | Home
Leaking pipe behhind shower head
See if there is a wall behind your shower stall you will have to open up the wall to fix your plumbing repair and patch the wall
Nov 20, 2015 | Home
My mx inspiration lxl as a leak from the overflow pipe behind the shower hose it only leaks when turned on this only happened when I changed the shower hose I had to take the shower cover off to do yhis
u need to change the Black Leather Circle, it comes between the shower hose and the pipe!! also check the shower hose from inside you may find some small stones and sands inside!!! i had this before and fixed it the exact same way i told you :)
Jun 08, 2014 | Home
Water leaking below shower
You may have a very small access panel on the front of the shower pan or through an access point in a cabinet on the backside of the shower wall. I have seen the shower tail piece get cut too short and as a result is becomes disconnected from the "P" trap under the shower.
Apr 04, 2014 | Dutchmen 2010 Grand Junction 345RE
Leak
1.How did you attribute the leak to the shower?
2. where did the water drip etc show up?
Jul 13, 2013 | Home
Hello I have a Heatstore aqua plus shower Model number 53594030. The overheating light is on and only cold water is coming out the shower has not been used for over 24hrs now and is still not working....
Hi
Im Rossouw
Jun 17, 2010 | Home
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Leaking faucet
Most likely bad solder joint or leak where shower arm is screwed into fitting.
Sep 26, 2009 | Home
My shower head leaks
for some reason the cartridge set up does a sporadic drip which is infuriating but replacing the insert will not fix it
after the cartridge there is just an empty hose to the shower head and no pressure
Nov 13, 2017 | Price Pfister R897EBK Brushed Nickel...
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
