Question about Fujifilm FinePix S4400 Digital Camera, Black
How do i reset time and date on the fuji s4400 camera
Time and date need to be reset how do i get into the right menu
  • 76 Answers
SOURCE: menu and ok buttons dont work. cant reset time/date
noway of skipping without having access to the buttons,im afraid but usually fault is caused by one of the buttons jamming and locking the rest of the keypad.pressing the buttons can usually locate the culprit as there is no movement.if you cant free the button will have to be brought to service.
Posted on May 13, 2007
  • 3 Answers
SOURCE: Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Posted on Oct 13, 2009
SOURCE: Loss of date and time on battery change
This is not a solution, however I have the very same problem, and as previously described, the problem have started recently after about two years. What make me think that there is an additional internal battery which died, similar to a PC battery that keeps the date and some other stuff
Posted on Jan 04, 2010
  • 241 Answers
SOURCE: Fuji E550 loses date and time every time i change batteries
Theres a small back-up battery located on the main
power board. It's not a DIY project to replace this battery.
Posted on Feb 19, 2010
Testimonial: "thank you...appreciate the help. :)"
  • 64 Answers
SOURCE: Why do I lose date/time
You lose the date/time because the camera has no power to it to keep the settings. Basically don't leave the batteries out if you want it to keep the date/time. On the other hand it will just sit and run the batteries down just sitting there off. It is a bit annoying but that's why. Most cameras store an internal charge so they can keep the date/time but it is not supposed to last very long, it was designed so you could swap out dead batteries without having to reset the time/date every time. If it is happening on simple battery changes it means something may be wrong with the camera.
Posted on May 17, 2011
Testimonial: "That information was as I suspected I shall have to get a power lead."
How do you change the date on a fuji s4400
Press the MENU/OK button. Press cursor-left then select the wrench icon. Press cursor-right, then use cursor-up/down to select the clock icon. See page 14 of this manual.
Dec 29, 2012 | FUJIFILM FinePix XP10 XP11 Digital Camera
Resetting date on Fujifilm S4400
If you cant find date on Menu would reset camera setting to Default and start all over.
Sep 20, 2012 | Fujifilm FinePix S4400 Digital Camera,...
Fuji s4300...reset time and date
Press the MENU/OK button. Press cursor-left, then select the wrench-SET icon. Press cursor-right, then select the DATE/TIME command.
If you need a manual, you may download a copy here.
Aug 13, 2012 | Fujifilm Finepix S4300 Digital Camera...
How can I change the date and time on my Fuji T200 camera, please
Use the MENU/OK button to the right of LCD screen in lower corner.
1. Press MENU/OK.
2. Press RIGHT side of selector to open Set Up MENU.
3. Toggle up/down to find the Date and Time setup.
4. Toggle with the selector to highlight year, month, day, hour etc
5. When each item is highlighted toggle up or down to find correct number.
6. When all are set press MENU/OK again to exit.
These instructions are on the manual which is on the CD that came with the camera.
Jul 01, 2011 | Fuji Cameras
How do you reset the time and date on the finepix jz500 digital camera?
Press MENU/OK to bring up the menu. Press cursor-left to highlight a tab, then use cursor-up/down to select the setup menu (wrench and "SET"). Press cursor-right to enter the menu, then use cursor-up/down to select "DATE/TIME", then press cursor-right. Use cursor-left/right to move between fields, cursor-up/down to change their values. Press MENU/OK when done.
Jun 08, 2011 | Fuji Cameras
I have a waterproof fuji camera and i cant figure out how to set the date and time
Press MENU/OK to display the menu. Use up/down to select Setup. Press right to display the Setup menu. Select Date/Time. Use left/right to select a field, up/down to change it.
Jul 08, 2010 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Fuji finepix z70, how do you reset the time and date
Press MENU/OK to display the menu for the current mode. Highlight the left tab. Select Set (with the wrench icon). Use up/down and scroll if necessary to highlight "DATE/TIME". Press MENU/OK. Use left/right to navigate through the fields, up/down to change them.
Jul 07, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
Describe to set date on fuji xp10P
Press MENU/OK to display the menu. Highlight the left tab. Select "Set". Use up/down to select "DATE/TIME" and press right.
This is on page 83 in my edition of the manual.
Jul 02, 2010 | FUJIFILM FinePix XP10 XP11 Digital Camera
Fujifilm FinePix S4400 Digital Camera, Black Logo
26 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
