Question about Philips DVD 622 DVD Player
PROBLEM HELLO i am having toshiba television which is a non-compatible for progressive scan(it is not a lcd or crt).i switched on that progressive scan in my dvd player modelno:622.it results in the display of blue screen.there is no any philipslogo displayed.what i want to do to switch off that progressive scan in my dvd player and retains its old position.
  • 5 Answers
Hold down 1 on the remote with the CD tray open. Should reset firmwire
Posted on Jan 06, 2008
Thanks for the solution it was driving me crazy, it worked like a charm.
Posted on Jan 22, 2008
SOURCE:
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
Component resolution why does it not want to do 480p
480p is used in LCD TVs to make the image look less pixelated. You have a CRT which doesn't support progressive scan
Feb 27, 2010 | RCA TruFlat 27F520T 27" TV
Do I have Progressive Scan on my TV?
component video is HD of sorts lower end of the scale. Your set has progressive scan..
Mar 26, 2009 | Televison & Video
Toshiba 40" 1080p plays dvds with a red tint and no sound??
When connecting the dvd player using component cables and audio cables, go to the progressive scan setting on the dvd player and select it. Once I activated the progressive scan, the problem was solved.
Jan 26, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Component connection does not support progressive scan DVD
No can do the set cant deal with that signal. turn off prgressive scan on the DVD the signal is still a preaty good one. Only blue ray or HD DVD will get the real HD.
Jul 10, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
"Unusable Signal"
Ok, I stopped short of going to Best Buy to get a new TV b/c my DAD suggested I pull the DVD player on another tv.
Dang it, he was right!. Same "audio no video" problem.
After playing with multiple buttons shooting blindly I found the [ I/P ] button restored the picture immediately!
This stands for Interaced or Progressive scanning:
from wikipedia
"Progressive or noninterlaced scanning is a method for displaying, storing or transmitting moving images in which all the lines of each frame are drawn in sequence. This is in contrast to the interlacing used in traditional television systems where only the odd lines, then the even lines of each frame (each image now called a field) are drawn alternatively."
So, my Dad says that "TV s are based on the interlacing" technology. I must have picked progressive scan while I was in the dark fast forwarding last week.
Mar 27, 2008 | RCA 27V530T 27" TV
Is a 2000 Sony trinitron Wega model # KV36FS16 High Definition compatible?
It is a 480i television only and not capable of HD or progressive scan from a prograssive scan input to the component connectors. Sorry about that...
Dec 06, 2007 | Sony KV-36FS16 36" TV
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Toshiba 30HF84 and progressive scan
check your connections properly there could be some thing that you are not connecting .or your cable are not compatible.good luck
Jan 23, 2007 | Toshiba 30HF84 30" TV
Philips DVD 622 DVD Player Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
