Question about Panasonic TH-42PX60U Television
Panasonic TH42PV60 Plasma,Vertical black bar at the center
In my TH42PV60 there is a vertical black strip one inch in width at the center and at the center of the black strip there is thin line appears,please someone help me to solve the problem.Is the Digital board damaged..? when changing the digital board should I need to change the firmware also..?
  • mikoyanvargh Feb 18, 2009
    In my TH42PV60 there is a vertical black strip one inch in width at the center and at the center of the black strip there is thin line appears,please someone help me to solve the problem.Is the Digital board damaged..? when changing the digital board should I need to change the firmware also..? As the fixya rxpert's advice I did but ends up with no result.
    Guru:
  • 832 Answers
Hey there! thanks for using Fixya.com!
I suggest that you should consult the specialist in regard with the problem with your plasma. Changing the digital board and upgrading the firmware must be done by the specialist, especially if you are not familiar with it, we just want to make sure that things will be done accurately.
thanks!
Posted on Feb 18, 2009
    Genius:
  • 1,550 Answers
Make sure the digital board is placed properly . Also check all connection from the digital board is correct with the help up of service manual . Check for any bad soldering .
    Sergeant:
    Champion:
  • 289 Answers
Hi..ya the reason to your problem wont be
the digital board.There might be the problem
in the chips that pass through the digital board.
No need to check firmware and all.Instead of
checking the digital board first make sure that
there is no problem in the chips.This could be
the reason for this problem.
check it out..
thank u..
Posted on Feb 12, 2009
  • Hariharanath V Feb 18, 2009
    hi..you first check out the chips that is inside
    the circuit board.There might be some problem
    in the chips,it might have some problem in the
    soldering.
    check this out..
    thanks..
    Master:
  • 848 Answers
Hi
initial hard reset - Just unplug the power cord leave the unit disconnected for 30 minutes and plug the power chord to the unit and it resets the unit ......
it tends to be digital board .....firmware update too can solve the problem..
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Black line going vertical through portion of
Connections on c boards, c board bad or bad panel. Disconnect power supply from sus boards on sides before attemting to disaconnect connectors from c board to flex cables. arc from stored energy on power board will burn cables. reseat the connector closest to the bar . reconnect power supply. Next replace that c board by strip. next replace plasma panel.
Dec 03, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Panasonic TH-42PX60U Television Logo
172 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
