Question about Seagate Computers & Internet
SRD00F2 SEAGATE EXPANSION How do I know when the backup is finished
SRD00F2
4 Suggested Answers
bschilz
  • 2049 Answers
SOURCE: Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Posted on Nov 06, 2009
bronk50
  • 27725 Answers
SOURCE: seagate expansion external drive backup
Determine how much space you need.
The first step in backing up your hard drive is to figure out how much space you will need to back up all of your files.
You can do this in a couple of ways.
Find out how large the hard drive is on your computer first to see if you can back up the whole thing. Click on "My Computer," right-click the "C" drive and select "Properties."
This shows the approximate size of your hard drive, how much space is actually taken, plus the space used by your operating system.
If your hard drive size is manageable (the space actually taken), back up the whole thing.
Your second option is to create a file called "Backup" and copy all of your important files into it.
Right-click on the folder once everything is copied over and choose "Properties" to find out the size of the folder.
This is how much space you will need to back up your important files only.
Choose a backup method. Choose either an external hard drive, data disks (CDs, for example) or use an online backup service.
There are advantages and disadvantages to all.
An external drive is convenient because you can plug it into other computers and immediately transfer or copy files without needing the Internet or having to worry at all about security.
However you have to carry the drive with you and always face the remote possibility that both your computer and the hard drive would break.
Data disks provide the same advantages and disadvantages as external hard drives: portability, but the possibility of theft or breakage.
You can also use an online backup service.
These services range in price depending on the amount of storage.
The advantage of an online service is that you can access your files from anywhere there is Internet, and it is generally cheaper, especially for small amounts of service.
Also, you don't need to carry or store another piece of equipment.
The disadvantage is your backup is stored on the service's external server, so security is a potential issue.
Back up your files. Once you have chosen your method of backup, do not forget the most important step: back up your files.
For external media, go into "My Computer" and double-click the "C" drive to open it.
Select all the files if backing up your entire hard drive, or select your "Backup" folder if just backing up your important files.
Holding your "CTRL" key, drag your selected files to your back up source, either your external hard drive or data disk drive.
Release your mouse button and "CTRL" key and allow the files to be copied onto your backup media.
hope this helps
Posted on Oct 23, 2012
SOURCE: manual for model no. SRD00F2 Seagate 3TB expansion drive
doesn't seem to work in Windows 7
Posted on May 29, 2013
Does the Seagate SRD00F2 have a power light?
http://www.seagate.com/files/staticfiles/support/seagate_external/Seagate_External_Desktop_Drv_QSG.pdf
Jun 19, 2014 | Seagate 3TB Expansion External Desktop USB...
Segate SRD00F2
Usually indicates the HDD has died
Nov 27, 2013 | Seagate 3TB Expansion External Desktop USB...
I only want to backup new information but the drive is backing up the entire hard drive each time. How do I change this?
Set your backup program to only backup the folders you need. You have it set to backup the drive. If your set up is to backup only "New" info, then the program needs to scan the drive to find out what is new.
Sep 08, 2013 | Seagate Expansion 2.0 TB USB 2.0 Desktop...
Seagate stbv3000300 srd00f2 wont work on tv
you shud check the specs of ur tv. Most of dem don't support mass storage devices. To run hardisk u need to buy a media players which supports storage device upto 1 tb.
If u want to run it so badly reformat the hardrive to FAT format from NTFC.
Dis shud solve ur problem
Jan 03, 2013 | Seagate EXPANSION EXTERNAL DESKTOP DRIVE...
How to backup files and folders
did you install the software included on the seagate?
if not install it and you can setup the back up/schedule.
or you can use windows backup to schedule backups to the seagate drive.
Mar 05, 2011 | Seagate FreeAgent Pro 500GB External USB...
How do i clone my hard drive onto an external hard drive
Are you using Windows? If you are using Windows, go to Start => Programs => Accessories => System Tools => Backup. In the backup wizard that opens, choose which backup type you want and you can choose your backup destination. Choose your Seagate Expansion external drive for your backup location so that Windows can store an image of your current system into your external drive.
Feb 09, 2010 | Computers & Internet
Nov 06, 2009 | Seagate Computers & Internet
Computers & Internet Logo
269 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
