Question about Water Heaters
Sun-flow ig-100 instant hot water heater model
Hello, can anyone tell me where i can find a diaphragm and other parts for this system. It is 20+ years old and had wrked beautifylly but need a diaphragm and one other part (unknown) that the tubes from teh diaphram lead into. Both are leaking. Any help would be greatly appreciated.
  • ks39 Jan 23, 2009
    robocop, tried that and it takes me to a business infomation site. i couldn't find any info on Sun Flow. Any other suggestions?
This unit was imported under different names....Try this link, the IG-100 is pictured...many parts still available.
http://www.plumbingsupply.com/mysonpartsbreakdown.html
Good luck, John
Posted on Jul 23, 2009
  • 90 Answers
Go to goliath.ecnext.com, exactly like I typed it, no www. and see if they can help you out. They make the Sun-flow products. Whether they still carry the parts for it, I'm not sure, but possibly they can head you in the right direction.
Posted on Jan 22, 2009
  • Bill Batross
    Bill Batross Jan 23, 2009
    Ok, Let me get back with U on that one, alright?
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
LB2280 leak
If this is instant heat faucet, then contact manufacturer.
Most these faucets have 1 year limited warranty
Replace faucet?
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Gene
Water Heater Timers Save Money
Dec 02, 2014 | Franke LB2280 Instant Hot and Cold Water...
Rheem RTG-66DVN shuts off 1-2 times a day
You received recommended answer posted ago.
Probably same answer today:
Don't install tankless, especially in location where there is no service technician available unless you expect to heat water by setting tankless out in sun.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Repair any brand tankless, any error code or problem, same day, yourself for $385:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add comment and give link to service manual that you located.
Apr 05, 2013 | Rheem RTG-66DVN Natural Gas Tankless Water...
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
I am not getting any hot water, only cold water, when I run my hot water taps. I have an Ariston Bravo water heater. Normally I have permanent hot water at any time. My central heating seems to be...
Sounds like the by-pass valve diaphragm. This valve detects that hot water is being drawn off at the tap and then diverts the mains input water across the heat exchanger. Very often it's the diaphragm inside the valve which is punctured or split.This can be replaced [depending on model] if you take apart the valve
. Remove the front panel and lower the control panel.The valve is at the bottom left of the boiler
Suggest turning off the service taps to the two heating pipes and the cold mains inlet pipes before tackling the valve
Mar 20, 2010 | Water Heaters
Noisy Rheem 16 instant hot water heater
About the only device in that heater that could cause the noise you describe is an electrically operated valve that controls water flow. Rheem is a better-than-average company so I would give them a call and describe your problem to them; I'll bet that they will be glad to tell you which part you need and supply it to you.
We had a heat pump system from Rheem that needed only the replacement of one large relay and the outside unit fan motor during more than 25 years of service and is still operating at age 30 in our former home.
Oct 03, 2009 | Rheem 81VP6S/430126 Water Heater
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Not producing hot water
the only time it's the valve is when you loose pressure on the hot side of any faucet, depending on the age of it you could just call the company bosch and they will tell you how far away a real tech is from you and contact them for you, you do have a 1 year labor 5 year parts warranty with the tankless unit, for you I hope you are within your warranty,,,, if not change it to a rinnai system the will send people to you if you have a problem
Jun 05, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heaters Logo
156 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
