Question about Xerox Phaser 8500/DN Printer
Xerox Phaser 8500 Pause
My Phaser 8500 is not printing. It is stuck on pause. Any suggestions?
Go into Control panel, Open the Printers/View installed printers.
Right click on your printer, and remove the "Pause Printing" check mark.
Posted on Feb 02, 2009
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
07, 010.43:35874 Error on Xerox Phaser 8560 MFP
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward tothe print position, due to problems.
1.Reboot the printer.2.Clean the print-head area (You should be able to manually push the print-head right to left.)
May 22, 2011 | Xerox Phaser 8500/DN Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 09.005.40:64314
Best way to do that is take a screw. I use a drywall screw, and twist them into the blocks and slide them back and out. Remove all of them, see if there is just one stuck or not compltely advanced in the loader. Then replace them all . That should clear the code.
Feb 03, 2010 | Xerox Phaser 8500/DN Printer
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500
Most likely your driver is corrupted. I would go to xerox.com and download a newer version and install a new driver.
Power off and power on your printer also.
May 15, 2008 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 reports Internal Error
I would suspect the elecrtonich module has gone bad.
Without an error tht is my best guess.
Oct 23, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
348 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
