Question about Canon PowerShot A520 Digital Camera
Partially closed lens when powering on Canon A520 Camera
When first turning on my Canon A520 camera, the lens cover doesn't retract fully, covering up two corners of my image. Simply tapping it with my finger makes the cover fully retract, but I sometimes forget in a rush to do that, and find the corners of my picture are covered Thanks in advance
  • 2 more comments
  • Anonymous Feb 18, 2008
    Both I and a friend have the same problem with our A520;s I tried lubricants and got it working on one but he lens was smudgy. Cleaning the wd40 off i jammed the lens and sent it to Canon.and they wanted 165.00 to fix it so i threw it out. Greg Toews on Fixya helped me fix my A630 Elf that just jammed up so maybe he has a solution. btw it makes for some cool romantic shots with that lens shutter half shut .
  • Anonymous Feb 22, 2008
    Same problem. I have tried silicone spray but it still sticks. Let me know
  • yuyaa Feb 02, 2009
    Same problem, I saw other A520 with the same problem,
  • Anonymous Mar 15, 2014
    canon g10 lens cover does no retract all the way leaving a diagonal **** for the lens
    Genius:
  • 2,985 Answers
This is a fault that Canon should know about- it may mean a replacement camera- therefore Canon Technical Support should be consulted.
Posted on Jun 26, 2007
SOURCE:
Lens cover won't open when Canon Powershot A520 Camera turned on
I have two Canon Power shots---the A610, and the A630. The lens cover is starting to hang on my 630 when the lens retracts.
If the lens is extended, take your fingertip and try to move the cover a bit to see if it springs open. If not, then the mechanism within the lens needs to be replaced.
Canon makes a great camera, and I would tell you to try to have it fixed if it costs less than 75 dollars. At 75-100 dollars it's a toss-up. More than a 100 dollars---it's your call.
Mar 26, 2009 | Canon PowerShot A520 Digital Camera
Canon sd630 dead
Lens is defective, change the lens
Nov 01, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Shutter Opens Partially
This is a common problem for the A520 (it happens on mine sometimes). Recommend trying only the simple fixes listed on the following web page, but do not recommend opening the front cover which is also listed here. The A520 is a little tricky getting back together.
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
May 17, 2008 | Canon PowerShot A520 Digital Camera
Canon Power Shot A520
Dear JudyCrossrds:
Due to impact damage your camera has suffered an obvious lens error and possible even sensor damage. It will have to be sent into the Facttory Service Center for a repair.
Call Canon Tech Support at 1-800-828-8080 to set the service up. They are open from 8 AM til Midnight, EST; M-F.
Hope this helps.
Sincerely,
HeavyDLB
Mar 21, 2008 | Canon PowerShot A520 Digital Camera
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Shutter cover opens partially in power shot A520
brother the camera gear system has got problems it seems. it happens due to misplacement of gears inside it.
even tough u can do it manually dont take risk of doing it manually untill u have full knowledge of internal parts. am from chenai. here in our service centre it costs around 1800 rupees for servicing it. so better take it to service centre.
Dec 23, 2007 | Canon PowerShot A520 Digital Camera
Casio Ex-z55 Lens cover not closing and lens does not operate
Buy the next camera- at 3 years old no economic repair will be feasible- but you could play with it some I guess
Aug 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Canon PowerShot A520 Digital Camera Logo
148 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
