How do i set the rates, canon TX-1210E - Office Equipment & Supplies
2 Suggested Answers
  • 5 Answers
SOURCE: TX-220TS
Enter you percentage of you tax rate.
Hold down the Rate button and the Set button (also TAX+)
Then release The Rate button.
Posted on Apr 27, 2010
We have a Canon 810 Fax Machine. How can we change the fax header?
change unit name
press additional functions button
then use the arrow - + buttons to select
tx/rx settings press ok
tx/rx common set.
tx settings
unit name
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
page 333 or section 12
Oct 28, 2016 | Canon Laser Class 810 Plain Paper Fax
How to disable ECM and Reduce Baud rate for Canon MF4270 G3 Fax ?
Your approach is correct however it doesn't look like the MF4270 provides for these settings. One might expect to be able to select G3 or ECM or set a lower TX speed.
I located the settings for different Canon Fax machines here:
VoIP Fax Settings
Jul 25, 2014 | Canon imageCLASS MF4270 All-In-One Laser...
I have a canon calculator TX-220H. Something has upset the tax rate. How do change it back to 10%?
Just follow these steps:
1) Enter the percentage of your Tax Rate (in your case 10)
2) Hold down the RATE key, SET key, and TAX+.
3) Then release the RATE key.
Your Tax Rate should now be set back to 10%.
May 15, 2011 | Canon TX-220H Calculator
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
How to print a tx report with canon L80 faxphone?
Here is a link to Canon for your FaxPhone L80 Users Guide. Reference page 14-3 to access the menus, page 14-5 for report settings, and 14-6 for TX Settings
http://gdlp01.c-wss.com/gds/0300000539/FAXPHONE_L80_Users_Guide_EN.pdf
Jan 07, 2010 | Canon FAXPHONE L80 Laser
Hi i have a canon L100 but the memorie is full, I can´t receive any document, can any one help me
Press the menu button go to TX settings,under tx settings scroll to "Erase faild TX" switch it to on.Then the memory will be cleard and it wount keep all the failed tx documents in memory.
Dec 02, 2009 | Canon Office Equipment & Supplies
How do I print a transmittal report after each fax sent?
Press the Menu button; use the right or left arrows to select device settings. Use the up or down arrows to select Fax Settings. Then TX settings.
Select TX report, then select to print a transmission report after each transmission, then select attach TX image. (This will attach the first page of the fax).
TX report Sets whether to print a transmission report after each transmission.
When Print error only or Print for each TX is selected, specify the following.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon ImageClass MF6590
Press the plus or minus sign to get to the "Report Settings" then press ok.
Under report settings select "TX Reports"
then set "Output" to YES
under that set "report with TX image" to ON
This will give you a confirmation with the image of you fax. Here is the manual, info on pg. 251
http://gdlp01.cwss.com/gds/0300000953/MF6500_BASIC_en_us_R.pdf
Thanks, Joe
Dec 11, 2008 | Canon ImageClass MF5770 Laser Copier...
TX-220TS
Jun 11, 2008 | Canon TX-220H Calculator
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
118 people viewed this question
k24674
jasbo
jasbo
