Question about Hotpoint Ultima WF860 Front Load Washer
Hi I have a Hotpoint Ultima WMD 940 with a fault code F06 - any suggestions. I have tried turning it off at the mains which worked up until this AM!
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
barkencoa
  • 3463 Answers
SOURCE: my Hotpoint Ultima keeps displaying an F10 fault
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Posted on Jan 17, 2010
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima washing machine showing fault code
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Thankyou.
Posted on Jan 27, 2010
SOURCE: I have a Hotpoint Aqualtis washing machine. It is not working
Check if the waste pipe isnt blocked.
Posted on Jun 28, 2010
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
My washing machine hotpoint ultima wmd 940 is dead no power ,but the fuse in the plug is ok.
the mains lead normally goes to a connector block at the top of the machine then onto a mains filter both of these can fail ie burnt out connections ect check these out first remember to un-plug machine first
Nov 10, 2014 | Hotpoint Washing Machines
Hotpoint ultima wmd 940 program counts down but machine not working
Good afternoon
Your washing machine has more difficult problems than I have met before.
The only thing I can advice you is to get an electrical expert from
a shop that specializes in your type of machine.
Whille you are waiting you could browse on the internet and look at MANUALSONLINE.COM
kolbrun
Feb 26, 2012 | Washing Machines
Hi i have an ultima wmd 940 hotpoint washing machine !! i have a split in the plastic piece which supplies water from the inlet to the tray!! what is this piece called and were could i get a picture of the...
a few sites yu can get on and actually type your model number and see the part you need are as follows:::
www.repairclinic.com
www.apdepot.com
www.sears.com
you should be able to type your model number on these sites and locate your part.
Jan 03, 2011 | Hotpoint Washing Machines
Wmd 940 wont fill,, water pressure ok,hose ok,f01
Solanoid. does it fill on any other programe. try hot wash, then rinse
Feb 01, 2010 | Hotpoint Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
125 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
