Question about Teledyne Laars HEAT EXCHANGER ASSEMBLY, DP-350 - 10403602
My laars jvt160pd11 has a cracked heat exchanger. can it be replaced .
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Teledyne Laars Master
  • 1,448 Answers
No need new one
Posted on Nov 06, 2014
3 Suggested Answers
  • 139 Answers
SOURCE: laars lite 2, mod-lg125n, sn. d03pj3400.
sounds like heat exch is plugged.remove top of unit and inspect for nests.could also be plugged with soot because of poor burner flame characteristics.with top off,turn htr on and look straight down into unit. you should be able to clearly see burner flames between fins. if not remove exchanger and clean
Posted on Jun 24, 2009
john224
  • 1378 Answers
SOURCE: when assembling header to heat exchanger is it
No...do not add anything to those gaskets.
Posted on Jan 21, 2010
Why would water come out of the air blower on my pentair master temp 400
take off top[ and see if coming from heat exchange or pressure switch leaking
Jun 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars ES125 repair manual
The exchanger alone will run $600 or more, and the headers aren't cheap either. Best to replace the heater. I have had customers do expensive repairs (despite my objections) only to have other expensive parts (T-stats, gas valve, burner tray..) break soon afterward.
Jandy is the closest relative of Teledyne, they used to be affiliated. RayPak has been making reliable heaters for decades.
Nov 23, 2013 | Teledyne Laars Pool & Spa
How to clean teledyne laars heat exchanger
take off top take off all baffles remove burn rack then rinse out with hose and wire brush to remove soot the best is if you can remove it so you can get to the bottom thats whats sooted up
Jan 17, 2013 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
My laars mighty therm keeps igniting on and over constanty, whats the problem
There is a problem with flame rectification. This could be caused by a dirty flame sensor, poor ground to burner, faulty ignition module, improper venting, inadequate combustion air, dirty burners, or clogged heat exchanger.
Jan 26, 2011 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
LLD125 pool heater leaking water from inside
My heat exchanger was cracked. I found an old welder who knew how to weld the cracks for $100 vs $900 for a new exchanger,. Also ordered replacement seals for the 2 chambers. I used high temp automotive engine sealant as an additional sealant precaution. Also inspected tubes and cleaned corrosion. Works fine last 3 years. Takes some mechanical skills.
May 18, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2, mod-lg125n, sn. d03pj3400.
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Lite 2 LG250N- Heat Exchanger cracked over winter
Yes I just had the same problem, the guy that I bought the house from told me to drain the pump and the filter,etc. But failed to mention there is three brass plugs on the side of the unit, so the heat exchanger cracked, but i took it to a general welding shop and they welded the crack up so that saved me a bunch of money That is all you have to do
May 16, 2009 | Jandy Laars Lite2 Lg 250,000 Btu Heater
Teledyne Laars HEAT EXCHANGER ASSEMBLY, DP-350 - 10403602 Logo
62 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
